Old 07-27-2010, 02:51 PM   #1
Green7mgte
Supra Forum Moderator
Default smoking from engine / oil loss
high guys problem with smoking on left side of engine twords the front and oil loss.
I removed my intercooler pipes and found a small amount of oil leading into the intercooler. also a trace amount in the accordion hose. and the 3000 pipe. so I know its time for my turbo to be rebuilt. But I don't see my turbo with only showing trace amounts of oil leakage creating a plume of smoke creeping from under my hood whenever I shut my car down.
smoke is comming from left side (turbo side) of the engine Near the Front behind the thermostat housing. any suggestions on were to go from here for proper diagnostics and replacement. Im leaning twords blown oil seals? any post you have bookmarked please pass my way as I am currently searching through the pages.
can we also go over the possibility of a clogged pcv? But I don't really see any of my air hoses being clogged. its possible tho.
as always, thanks for any input and guidance.
thanks in advance
Green7mgte.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 07-27-2010, 03:05 PM   #2
thanks in advance
Green7mgte.
that would be the right side actually. it's decided from the perspective of the seated occupant.
the outside leak could be coming from the distributor.
actually, oil exiting into the intake indicates the pcv is doing its job... if there is a lot you may have excessive blow by.
Old 07-27-2010, 03:18 PM   #3
Green7mgte
meaning the Cam positioning sensor? maybe the packing in there is worn?
that location is just about were the smoke is coming from? would that leak oil? the packing or the O ring?
Supra FAQ
Supra MKIII FAQ
Old 07-27-2010, 08:06 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Yep, that definitely sounds like the cam positioning sensor O ring Part # 9099-14018. The oil drips on the front part of the exhaust heat shield, as soon as you lift the hood you can smell oily fumes. Link O ring marked with a yellow arrow in pic.
Old 07-28-2010, 01:49 AM   #5
Sorry, wasn't thinking... for this dialogue they're the same though... The dizzy and CPS both have an outer seal and both can also leak internally (not something that's easy to remedy). Take the cap off the CPS to see if there's oil on the inside which is escaping through the weep in the bottom of the CPS housing. The O ring I recommend just replacing, you've got to pull the CPS to check it anyway and it's DIRT CHEAP.
SOME oil in the intake is normal from both the PCV system and from the turbo's oil seal... there are ALWAYS oil vapors being carried with the blowby gasses being removed by the PCV system and there is ALWAYS oil escaping the turbo's oil seals. HOWEVER, this oil should not accumulate in any appreciable amount in a few months time. On an older MKIII I'd say that more than a table spoon of oil drained out of the intercooler after cleaning it out three months prior is way too much, BUT still plenty driveable. If you're seeing a loss of half a quart between fuel fillings I bet there's a decent amount of that sitting in the Ic and it's time for an overhaul.
Old 07-28-2010, 01:51 AM   #6
Green7mgte
I do see about half a quart or more between every couple fill ups. what do you mean overhaul? a good IC cleaning or an engine rebuild.. gasp*
I can see my oil dripping from the bottom of my engine. Left side beneath the manifold twords the front. bottom of the engine, right were the block meats the oil pan. could this be an internal leak from the cps
whats a recommended step along with check for leaking in the cam sensor.
Supra FAQ
Supra MKIII FAQ
Old 07-28-2010, 02:00 AM   #7
You need to fix ALL external leaks before you can be sure how much you're loosing internally... BUT the amount which collects in the IC is a good indicator as to where things are.
I meant a rebuild when I said overhaul... shouldn't have used that term, it's vague.
Putting JDM engine in!!! :D dannydavi MKIII Supra 24 11-02-2009 06:30 AM
WOW abrupt engine issues on new jasper. Kuban MKIII Supra 26 06-20-2007 05:15 PM
