Old 07-05-2010, 07:25 PM   #1
ReelBandit
ReelBandit is on a distinguished road
Default Oilpan Removal????
Has anyone ever removed the oil pan with the motor still in the car? I've removed everything that the book says and then some. According to my manual it says to lift the motor "slightly". I've done that and more and still cant get enough room to bring the oil pan back enough to get it to drop..
1987 Supra Targa 7MGTE 5 speed
ReelBandit is offline   Reply With Quote
Old 07-05-2010, 08:18 PM   #2
slightly = 8 - 12" IIRC
Old 07-05-2010, 08:31 PM   #3
ReelBandit
Can it be done without removing the engine?
Old 07-05-2010, 09:09 PM   #4
takes allot more than 12" to remove the engine.... so, um, yeah.
Old 07-05-2010, 09:48 PM   #5
batmmannn
batmmannn's Avatar
Default Run a search
Lots on the web about this. People say you have to do a lot of work to get that off including dropping the crossmember, unhooking the exhaust, lift the engine, remove the drag link.....UNNNGHHHH!
Old 07-05-2010, 09:51 PM   #6
wstanek
wstanek's Avatar
i was planing on doing my rod bearings from the bottom but we might have to change that plan... D=
1987 N/A 7MGE manual transmission slight rod knock never driven it yet... legally~
Old 07-05-2010, 10:08 PM   #7
ReelBandit
Well, so far, I've all but removed my engine, its hanging partly out of the engine bay right now. The book made it sound like most others, but NOT in this case...
Old 07-05-2010, 10:23 PM   #8
batmmannn
batmmannn's Avatar
Default Might as well pull it
If you have it that far you might as well just pull it. I have seen pics of them pulled with radiator removed and the trans still attached. Do the rear main crank seal and clutch plate while you are there. Can you throw some pics up so we can see your progress?
http://www.toyota-supra.info/forums/...n-leaking.html
Old 07-05-2010, 11:25 PM   #9
Can't do the main bearings or rear main seal with the transmission attached.... for that pull the engine.
Pulling the pan with the engine in the car isn't hard (been there done that). Personally, I'd recommend just pulling it, but I've had it off with the engine in the car and the wire harness all still connected. I have no idea what your problem is; you've just got to get the front of the engine elevated a dozen inches or so (I think it was closer to 8") and you don't even need to pull any cross members. Is your engine swinging forward as you lift it? Do you have a leveler?
Old 07-05-2010, 11:33 PM   #10
ReelBandit
Yes I have a leveler. It just seemed no matter what I tried I still lacked a 1/2" of clearance to get the pan off.( with the tranny attached) Doesn't really matter now that I've pulled the motor partially out. I forgot to bring my camera today or I would upload pics. Gunna call it a day for now. I will be back on it after work tomorrow. Can the oil pump be rebuilt???? Thanks for all the input!
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Rack and pinion removal fasteddy5000 MKIII Supra 2 04-05-2010 02:16 PM
Alternator belt removal and installation! ~*B Magical*~ MKIII Supra 11 03-13-2008 07:27 PM
Fuse Removal + Nice Supra Pic jdbones Non-Generation Specific Questions 0 01-28-2008 01:01 AM
