Old 07-01-2010, 01:49 AM   #1
SuperSpartan
SuperSpartan's Avatar
SuperSpartan is on a distinguished road
Default Engine Light after Replaced Engine
So i replaced my old engine which got rodnock and got completely torn up, and thats when i got the check engine light.
Now the other 7M-GTE is in and works great with everything besides my faulty starter which ill find out when i get the new one. Also if anyone has any advice on a bigger more powerfull starter thatll last better than those Denso ones, for my 90 Turbo thatd be helpfull. Back on topic
I have my Check Engine light on and it sometimes flashes any ideas on how i can remove the light so i can at least code my car?
Any information would be great. Thanks!
1990 Toyota Supra Turbo!!
www.cardomain.com/ride/3067504
SuperSpartan is offline   Reply With Quote
Old 04-15-2011, 06:44 PM   #2
interested!
Default engine light
Hi!
My supra was suffering from an intermittent flashing engine warning light -initially I would remove the fuse to reset , eventually I found that after reading the code that the only step was to replace the airflow meter ASSY and this cured the problem-genuine ones not cheap through main dealer-no problems with this now.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
check engine light & bulb light, what? nosuprayou MKIII Supra 2 12-19-2009 09:15 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
Engine Light Supra91_ishot Non-Generation Specific Questions 2 06-08-2005 12:37 PM
