Old 06-25-2010, 02:41 AM   #1
joshtexican
joshtexican is on a distinguished road
Default Changing gear oil in W58
Does anyone know or have a few basic steps on how to change the gear oil in a w58??
I had some leak out as I was doing my swap and was wondering if I can go ahead and change it out with some fresh.
Thanks
joshtexican is offline   Reply With Quote
Old 06-25-2010, 03:09 AM   #2
nothing special and its a good thing to do.
its easy too! just fill up until it overflows on your hands....
at least thats what happened on my samurai
Old 06-25-2010, 03:25 AM   #3
joshtexican
ok cool, where do you fill it up??
Should I go ahead and drain everything and give it new oil?
Old 06-25-2010, 12:51 PM   #4
if you want to it would not hurt..
and if a considerable amount came out in your swap than i would.
its easy man, i would take a picture or somthin for you but you CANT MISS IT! and need to be on my way to work soon...
drain plug is right on the bottem of the transmission, big freakin bolt that holds all the fluid in. the fill plug is close, cant remember what side of the tranny its on but you will see it...
Old 06-25-2010, 01:33 PM   #5
joshtexican
Ok cool drain plug , got it...
To fill it...ummmm are we talking with the tranny out of the car? or can the fluid be changed with tranny in the car??
Old 06-25-2010, 11:00 PM   #6
Busted Knuckles
Busted Knuckles's Avatar
In the car. The fill plug is on the driver's side, middle of transmission, half way up. Can't miss it. I have a hand pump to pump gear lube from the container into the transmission. Just pump until the fluid trickles out, and your done.
Old 06-25-2010, 11:45 PM   #7
joshtexican
Ok cool, Thanks bro
Really appreciate the info!!
1st gear jumping out, 4th gear crunching, how do I fix it without changing gearbox wcrispino Non-Generation Specific Questions 7 01-31-2010 11:13 AM
Changing LSD oil. redmaro MKIII Supra 8 04-28-2007 11:13 PM
changing gear oil Levi1717 MKIII Supra 10 01-08-2007 03:34 AM
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
changing out ring gear Burn N' Up MKIII Supra 0 08-30-2006 07:09 PM
