Old 06-17-2010, 08:16 PM   #1
AlexSchuSupra
AlexSchuSupra's Avatar
AlexSchuSupra is on a distinguished road
Default Feel like an idiot here.......1JZ-GTE have spark plugs?
Feel like thats a really stupid question to ask, but when I took off the cover today all I saw was these packs... and I was too scared to mess with them since i have no idea what they are. A little advice here would help. Reason I was thinking I may need to replace spark plugs or at least check them is because I am idling funny. My idle is low... which I think I will have to turn up a bit but it is lightly tossing between 500 and 700, sometimes just to 600. Don't know what that means for sure, but I swear sometimes I feel the tinniest hiccup from the supra when slowly driving in 2nd gear and letting the rpm's raise to about 5k.
Thanks!
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
AlexSchuSupra is offline   Reply With Quote
Old 06-17-2010, 11:39 PM   #2
wstanek
wstanek's Avatar
wstanek is on a distinguished road
Well considering its a gasoline engine... Yes they do all gasoline car engine will have spark plugs they will be under the coils just look i'm a 7m guy not a 1jz
wstanek is offline   Reply With Quote
Old 06-18-2010, 12:02 AM   #3
bryanf89
All combustion engines have spark plugs, the coil packs are you used to distribute the electrical spark
Old 06-18-2010, 12:12 AM   #4
wstanek
wstanek's Avatar
wow made a mistake was thinking of my nitro rc lawl just ran it haha
Old 06-18-2010, 02:15 AM   #5
907mge
907mge's Avatar
Most likely the coil pack goes on top of the plug. My celica has four individual ones. At least there are no plug wires to replace.
Old 06-18-2010, 03:59 AM   #6
AlexSchuSupra
Sweet. Figured they had some kind of new stuff with the silly 4cyl engines nowadays I had seen on a Sentra. Anyway cool i'm gonna go pull them off then and see how they look. Probably pretty bad since the car had an n/a map sensor on for so long
Help...My spark plugs are in the oil !!! chinesedawn MKIII Supra 6 10-03-2011 09:25 PM
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
