Old 06-09-2010, 05:44 PM   #1
bryanf89
Default Rotary Engine on the supra?!
so i was reading up on rotary engines and found out that they could make a whole lot of power whill still remaining at 2.0L or smaller....has any1 ever put a rotary engine on a MKIII supra?
What do you guys think? i just want to hear opinions, i dont plan on doing this, im happy with my 7m
Old 06-09-2010, 05:50 PM   #2
-Original post edited-
Old 06-09-2010, 07:37 PM   #3
turbonicsperformance
the supra is way too heavy for a rotary they make loads of power but no torque and you need torque to get 3400lbs going the great thing about rotary engines is that they rev out to 12-13k or higher very easily and make power straight through the rpm range but at like 1000hp theyll make about 400ftlbs or less
Old 06-09-2010, 08:21 PM   #4
bryanf89
hmm fullthrottle we should patent an idea of combing the toque of an piston engine and the HP of a rotary, like a hybrid lol
now that i think about it, that would be AWESOME...your have the best torque and HP with an high redline
anyone here has a masters degree in mechanical engineering?
Old 06-09-2010, 10:18 PM   #5
907mge
907mge's Avatar
leave the wankel in a mazda
Old 06-09-2010, 10:28 PM   #6
wstanek
wstanek's Avatar
ya is u say "Mazda" slowly kinda sounds like "Rotary". haha just kidding but leave it in the Mazda... =D
Old 06-09-2010, 11:34 PM   #7
bryanf89
lol yea i could do that...ok another idea, a rotary engine on a rc car lol
Old 06-10-2010, 03:03 AM   #8
only thing ive ever seen a rotary good in besides an rx7-8 is a suzuki samurai i know a guy running a rx7 turbo engine and trans in his it runs awesome but only because hes running 1st gear=3.5 tcase 4-1 tcase 4-1 axles 5.13 thats a very low ratio final drive of 287-1 but he can run 1st gear through 12k so it actually gets up and goes lol helps that a sami only weighs like 1500 lbs
Old 06-10-2010, 04:44 AM   #9
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
Ive built a couple rx7 in my day... And by all means... your comment.
But... one mans word of mouth wont speak... so ill show u different with the internet... wikipedia
The 13B-DEI was turbocharged in 1986. It features the newer four-injector fuel injection of the 6PI engine, but lacks that engine's eponymous variable intake system. In '86-'88 engines the twin-scroll turbocharger is fed using a two-stage mechanically actuated valve, however on '89-'91 engines a better turbo design was used with a divided manifold powering the twin-scroll configuration. For engines manufactured between '86-'88 output is rated at 185 hp (138 kW) at 6500 rpm and 248 N·m (183 ft·lbf) at 3500 rpm.
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
1983 supra engine question 101jinx101 MKII Supra 0 12-06-2007 10:47 AM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
