Old 06-06-2010, 04:34 PM   #11
If the speedo's only a constant 2MPH off then your tach's screwy or your igniter is... Roll the car slowly across a measured one mile segment of road and see if the odometer is reading accurately. If it's right on the mark just more the speedo needle to set everything right.
And if your speedo is 2 MPH off at 10MPH and still only 2MPH off at 100MPH feel lucky, the speedo was blessed by god himself.
Old 06-06-2010, 08:13 PM   #12
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
http://www.toyotaparts123.com/partlo...5450&year=1992
store to buy OEM parts.
spirit of the supra hu. cool. good luck with your build. welcome to the board.
Here is a online price comparison for the same part:
Passenger side door molding 86-88.
Toyota World $166.42
Toyota Parts Barn $162.50
Toyota Parts 123 $156.50
Shipping and taxes (if any) may vary depending on where you live.
Old 06-07-2010, 03:44 AM   #13
turbonicsperformance
turbonicsperformance is on a distinguished road
its 2 mph off at 20 30 40 50 but he is still a cop and wouldnt let me speed so i couldnt test any faster and what did you mean by "more the speedo needle" im sure its just a typo but i cant think of what you might be trying to say
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 06-07-2010, 04:09 AM   #14
Meant to say, "move". Pull the needle off, and put it back on so it'll show correctly.
Old 08-23-2010, 06:34 PM   #15
Ranma
Ranma's Avatar
Talking
cre, the policemen in Oklahoma are anal retentive. Got pulled over for doing 79 in the 75 mph of the Will Rogers. Probably next time I will get a regular ticket instead of the warning.
Can it be fixed, is removing and replacing best? I hate the ideal of having after market stuff blocking my view.
Old 08-24-2010, 01:19 AM   #16
Green7mgte
Supra Forum Moderator
yea i just dropped a link from one of my book marks. I have several companys I go through for oem parts. In fact when I want to buy something I load all of them and see which one is the cheapest.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 08-24-2010, 04:14 AM   #17
If the speedometer is off but all the gearing is right you can recalibrate the gauge. There is an arm behind the face which adjusts it my percentage and flat out moving the needle is what you'll do fix a constant offset (ie: it's ALWAYS 5 MPH low).
If the gearing does NOT match you may swap out the speedometer driven gear or worst case swap out the diff to make everything right.
You may recalibrate the gauge to make the speed report accurately without changing any gearing (diff or speedo drive gear) BUT the odometer will still be off.
When changing to a different diff the proper course of action is to change the speedometer drive gear for one the appropriate size or to install small gear box which changes rate at which the speedometer cable spins (there are actually shops that do just this).
Tags
differental gearing
Major changes to the '89 model Cutback MKIII Supra 3 11-13-2009 02:26 AM
wats the gear ratio on an mk3 rear end? suprabilly21 Non-Generation Specific Questions 3 05-08-2007 12:01 AM
Rear ended Gmrwizard MKIII Supra 1 02-24-2006 01:33 PM
