Old 06-03-2010, 03:30 AM   #21
Pennzoil Platinum 5W-30. I change my oil filter 3x more often than I change my oil.
Old 06-03-2010, 03:55 AM   #22
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
I wonder why people put synthetic in their cars...
Synthetic oils were used mostly only in airliners to keep the oil from freezing in the frigid temperature they mostly fly in. Spoken to a few other mechanics about using synthetic oils, and they mostly all have said "Why pay double for overkill..."
Not bagging on anyone, just wondering why pay 14$ a quart for oil...
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
Old 06-03-2010, 04:41 AM   #23
btwilson86
Super Moderator
btwilson86's Avatar
I ran 0W-20 Royal Purple engine oil in my former 87 7MGTE. I had not experienced any significant loss of pressure, and in turn had a cooler, better performing engine. I switched from 5W-30 Mobil Clean 5000 conventional oil.
My reasonings for switching:
1: Extended oil life and better protection because a Synthetic oil's structure does not break down from normal use
2: Ability to reach thinner viscosity at startup, therefore providing better flow and lubrication for the engine during a traditionally high-wear period
3: *Most* Synthetic oils have been proven to adhere better to metal surfaces versus a mineral-based conventional oil, once again providing better lubrication (people may argue this point, as I have no data at hand to prove this; it's just something I've read a couple of times over the years)
4: Increased lubrication results in less friction. My engine now runs smoother, quieter, and is much more responsive vs. conventional oils I have run in my Supra.
With that said, there is a lot of bad information about what oil to run, how different oils work, and what's best for what scenario. Most people will believe what they believe for their own reasons, the only way to know for sure is EXTENSIVE research and experimentation.
Old 06-03-2010, 05:09 AM   #24
I'm with BT.... hell, the only reason conventional oils are able to provide even half the wear and thermal characteristics its because of all the synthetic additives and unnatural altercation they put it through. you really can't get the goodol' oil you used to... and for a good reason, comparatively it sucked!
Old 06-03-2010, 01:23 PM   #25
wstanek
wstanek's Avatar
wstanek is on a distinguished road
lol so true theres alot of additives in standard oil now.
wstanek is offline   Reply With Quote
Old 06-04-2010, 02:35 AM   #26
Green7mgte
Supra Forum Moderator
so common consensus besides the royal purple. 10w30? 40? 5w50?
if i were to buy a supra tomorrow. what oil would I use.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-04-2010, 06:03 AM   #27
btwilson86
Super Moderator
btwilson86's Avatar
I would also say 0W-30 is acceptable
Old 06-05-2010, 06:17 AM   #28
mkiiisupra
Ive been running 5W-30 redline synthetic oil, Bes oil in the buisness
Have to order it from summit though have not found locally
Vavle train noise decreased drastically. MPG increased by 2 and on top of all the my rear main seal leak nearly completly vanished
http://www.supramania.com/forums/for...amp-Filtration
If you want more info on why its the best check out what jdub and others have to say about it.
1990 Toyota Supra Turbo A/T
Old 06-05-2010, 10:24 AM   #29
batmmannn
batmmannn's Avatar
Default Impressive
Thats quite an impressive report there cause a lot of us have valve train noise. I am going to have to check that out. Do you run the same oil in Winter and Summer? Thanks, Scott
Here is some info on it. Its 8.75 a bottle on ebay.
Provides the quickest starts and fastest oil pressure rise. Will reduce turbo lag and provides more power and best economy in an engine in good condition. Replacement for OE factory-fill oils in passenger cars and most light trucks, including most new GM cars and trucks. Thicker oil film at operating temperature than a petroleum 10W-40. Best choice for engines operated in extreme cold weather.
Red Line’s synthetic motor oils are designed to provide the highest protection, cleanliness and superior drain intervals with the lowest friction for your gasoline, diesel, motorcycle or marine engine. We use the most stable components available and formulate our products for wear protection and friction reduction across a wide range of engine operating conditions. Red Line's products are unique because they contain polyol ester base stocks, the only lubricants which can withstand the tremendous heat of modern jet engines. These synthetics have a natural multigrade property which allows our chemists to avoid bulking up an oil with unnecessary additive packages.
Old 06-05-2010, 11:04 AM   #30
joshtexican
joshtexican is on a distinguished road
Do you guys use the same type of oil at a fresh rebuild?
or do you use a certain wt at during break in?
joshtexican is offline   Reply With Quote
Buying supra need advice guys sisqojazz Non-Generation Specific Questions 1 03-21-2007 10:47 PM
Hey guys, should I purchase this? ravE MKIII Supra 1 03-18-2006 08:09 AM
Can some of you guys give me some info on these cars? Big Jimbo MKIII Supra 5 01-07-2006 08:24 PM
Sup Guys..!!!! Ruben Non-Generation Specific Questions 29 07-06-2005 09:38 PM
