Old 08-30-2005, 08:41 PM   #1
Guest
Guest
Posts: n/a
whats the best way to port the exhaust mainifold on this car me and my boy have the mainifold off the car and we r tryin to get the gases to flow 2 the turbo better pics r great if u can the tools and how is the ''best way'' 2 do it thankz
Old 08-31-2005, 04:36 AM   #2
Poodles
Poodles is on a distinguished road
haven't heard of anyone porting the manifold... sounds like a bad idea because of the amount of heat it has to take...
Poodles is offline   Reply With Quote
Old 09-01-2005, 02:57 AM   #3
Intenseneal
Guest
Posts: n/a
The easy may to port a manifold is to get a new gasket, remove the manifold from the head, place the gasket on the manifold mating surface and out line where the manifold sticks out from the gasket. Them use a dremal tool to cut away the extra material. The same thing can be done to the head's exhaust ports so that the exhaust flows freely through the ports and the manifold. I would mess with the head unless you have it off the car. You can pick up a few HP with this and should see better turbo spool.
Old 09-01-2005, 03:13 AM   #4
monkihead
SP58GT
monkihead's Avatar
if you dont have a flow bench you can hurt power by doing so. its easier to get an aftermarket manifold. secondly, if you cut the cast iron one too much it can crack when heated.
monique- better off dead
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte front clip supraman121 MKIII Supra 4 05-31-2007 01:27 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
