Old 05-20-2010, 02:38 AM   #11
turbonicsperformance
turbonicsperformance is on a distinguished road
seems like alot of work just for a header i hope my obx doesnt need as much work im hoping to just bolt it in and go lol
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 05-20-2010, 02:40 AM   #12
907mge
907mge's Avatar
the problem is that they seem to look the same
Old 05-20-2010, 02:43 AM   #13
907mge
907mge's Avatar
Old 05-20-2010, 03:18 AM   #14
batmmannn
batmmannn's Avatar
Default 3" Exhaust
At what point does the exhaust expand to 3" for what everyone is calling a 3" exhaust. Does this type of exhaust connect to the stock headers? Does it expand from the cat convert back?
Old 05-20-2010, 01:27 PM   #15
yes the 3 inch is a cat back system the header replaces the cat though for a full catless exhaust but its a 2 inch pipe then joins into your ehxaust whether it be stock or oversized
Old 05-20-2010, 02:39 PM   #16
907mge
907mge's Avatar
So I got it to settle down now after disconnecting the sensor and it took alittle bit but smoothed out. I'm think that the sensor is too far back in the pipe and not getting hot enough.
Old 05-21-2010, 02:57 AM   #17
sounds reasonable though it should be self heating and it doesnt go off of heat it actually reads a/f ratio did they put the sensor up off of the exhaust? like did they use an anti fouler or anything to compensate for the cat alot of muffler shops will do this thinking its necessary because their used to doing newer cars
Old 05-21-2010, 10:30 AM   #18
907mge
907mge's Avatar
its just a normal o2 senor, but what do you mean by anti fouler?
Old 05-22-2010, 04:56 AM   #19
alot of people use a sparkplug anti fouler (found at autozone or advanced auto in the help section) it raises the o2 up out of the exhaust and limits the flow to basically simulate a working cat
Old 05-23-2010, 10:13 PM   #20
907mge
907mge's Avatar
In the old cast iron manifold the sensor is pretty well in the flow with it being between the two banks of 3 about 6in from the exhaust ports. Now what i'm trying to do is figure out if I can weld the downpipe to the header and still be able to get it out of the car.I'd like to wrap it further down and knock down some of the noise coming from it. It sounds like a v8 with open headers under the hood now. And I plan on moving the o2 location up the pipe much farther. It does make a nice inprovement in power though, not sure how much but noticable.
n/a advice dj7mge MKIII Supra 0 07-25-2009 06:19 AM
Buying supra need advice guys sisqojazz Non-Generation Specific Questions 1 03-21-2007 10:47 PM
good news bad news and whazzzzuppp supras sharkn MKIII Supra 5 10-09-2006 04:23 AM
***Need expert advice on a 2JZGTE swap in a Lexus*** sixfourbolt Non-Generation Specific Questions 4 08-27-2006 08:30 PM
header supra_91 MKIII Supra 4 04-13-2006 10:36 PM
