Old 05-19-2010, 03:25 PM   #1
lostsurferinbc
lostsurferinbc is on a distinguished road
Default need some timing info (searched)
i found what i need threw search except for 1 thing. yesturday i took out the distributer to change out the old O ring and i was in such a hurry i forgot to mark the distributer. what i need to know is where should the distributer be pointing a tdc?
lostsurferinbc is offline   Reply With Quote
Old 05-19-2010, 03:57 PM   #2
FRISBEE
FRISBEE's Avatar
If I remember right, If your now at TDC#1 there should be some notches on the gear dirve and you'll need to line those up to where the wheel is right on the sensor. Check your timmng.
1992 Honda Prelude 400Hp ??TQ
14.0@ 114MPH Time for Update
2007 Cadilliac Escalade daily
Old 05-19-2010, 06:07 PM   #3
lostsurferinbc
are these the notches? and which lines up with which. I have the mark on the crank pulley lined up with 10 tdc
Old 05-19-2010, 06:37 PM   #4
lostsurferinbc
thanx for the help, i got her to fire up, now i just need to grab a timing light
Old 05-19-2010, 10:40 PM   #5
FRISBEE
FRISBEE's Avatar
make sure to lock out the timming at the jumper.
Old 05-20-2010, 12:01 AM   #6
Wait, you have it set at 10? BTDC while installing the distributor? When installing the dizzy, you're timing marks should be set at 0?, with the engine at TDC on the compression stroke. When you set your ignition timing, you will then rotate the dizzy until you're firing at 10? BTDC.
As FRISBEE said, don't forget to put the jumper wire in when you set the ignition timing
Old 05-20-2010, 03:53 PM   #7
lostsurferinbc
ok thanx, ill do that, since i just took the distibuter out and the never touched then cams everything is timed except the distibuter
Old 05-20-2010, 04:38 PM   #8
907mge
907mge's Avatar
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=19
Exhaust vs Timing, something else? Krem MKIII Supra 9 03-18-2010 02:39 AM
timing problem with knock robertsws MKIII Supra 1 09-04-2009 03:40 PM
Timing question Kevin MKIII Supra 3 07-10-2009 07:52 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
timing issues stuck1 MKIII Supra 0 03-27-2006 02:16 PM
