Old 05-11-2010, 03:58 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Originally Posted by fullthrottlesrqsupra View Post
one full size all the way back actually ending up a tiny bit smaller at exit
Actually, you want to start out smaller and end up larger. After combustion you want a smaller diameter pipe to maintain the velocity of the hot exhaust gasses. The further the gasses travel, the cooler they get. When the gasses cool down, their velocity decreases causing more restriction in the flow. To avoid this, you increase the pipe size, allowing more gasses to occupy that portion of the pipe.
So, start smaller, end bigger.
Let the arguments begin lol
Old 05-11-2010, 01:53 PM   #2
supraflymkiii
supraflymkiii's Avatar
supraflymkiii is on a distinguished road
^^That was the jist of what I was trying to say.
supraflymkiii is offline   Reply With Quote
Old 05-11-2010, 03:24 PM   #3
907mge
907mge's Avatar
Here is a pic of it now with the exhasut wrap on it.
Old 05-12-2010, 03:20 AM   #4
turbonicsperformance
turbonicsperformance is on a distinguished road
yeah true i was thinking backward (pressure rather than flow) my bad but the sudden increase in size gives you alot of backpressure so try and avoid it either way and the header looks like it will be fine the way it is the wrap is gonna void your warranty and make sure you keep an eye on it for corrosion the wrap is known for causing it
turbonicsperformance is offline   Reply With Quote
Old 05-13-2010, 12:28 AM   #5
907mge
907mge's Avatar
It is a pacesetter there is no real warranty. I had to modifiy it just to get it to fit. I had to remove the non hightemp paint first then paint it with good high temp paint. After that I took and wraped it and sealed it with the hightemp silicone that came with the kit. I'm hope it still doesn't rust.
Downpipe Advice cgreiner MKIII Supra 2 03-16-2009 01:34 AM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
downpipe question boogum7 MKIII Supra 5 11-06-2006 02:32 AM
3" Downpipe Reeves MKIII Supra 10 08-31-2006 10:35 PM
Divorced Downpipe VS. 1 piece elbow-downpipe 87sleeper MKIII Supra 1 10-04-2005 04:50 PM
