Old 08-30-2005, 04:08 AM   #3
mrnickleye
mrnickleye's Avatar
Originally posted by daiagaru2@Aug 30 2005, 01:49 AM
a leak down test consists of compresing the cylinder and listening to the exhaust and intake valves.if you can hear air comming out of either you have a failure.i would get a compresion tester,pull all plug wires remove one spark plug at a time install compression tester(screw in kind)and crank engine until preasure is at max then simply listen to the exhaust valves for air leaks,then listen to intake vaves for air leaks.
You'd be wasting your time, as that will not work. You must have a pressurized air source and an adaptor to do a 'cylinder leakdown test'.
Perhaps 87supraturbo was refering to a cooling system pressure test. If so, it would be cheaper to have a shop do it, as cost of the tester is not low. Plus a shop can test for a BHG at the same time.
Free $$ to fix failed smog test cars - CALI specific mrnickleye Non-Generation Specific Questions 2 06-19-2008 12:20 AM
Picking up Block Test Today scruffboy Non-Generation Specific Questions 4 06-02-2007 05:07 PM
3" Test Pipe cars4me89 MKIII Supra 2 07-27-2006 03:26 AM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
Test....... midwestmk2 MKII Supra 0 12-21-2005 08:40 AM
