Old 05-03-2010, 04:37 PM   #1
86.5supra
86.5supra is on a distinguished road
Default Supra Wont start please help!!!!!!!!!!!!
I have a 86.5 supra that was converted over to a 7mgte w/r154 tranny. All work was professionally done about 3 years ago or 10000 miles. Finally got the chance to take it out for the summer (no more snow). It ran perfect for the first couple times out about 400 miles. Now it WILL NOT START, the car will crank and crank untill the battery dies. Any suggestions will help, this is my last option before i have to take it to Toyota (which i would like to avoid).
86.5supra is offline   Reply With Quote
Old 05-03-2010, 05:52 PM   #2
jdmsoup
jdmsoup's Avatar
jdmsoup is on a distinguished road
does it like completely start over and over?
jdmsoup is offline   Reply With Quote
Old 05-03-2010, 06:17 PM   #3
86.5supra
i'm not sure what you mean. If you turn the key it just cranks like it wants to start. I know its getting fuel (pressure test yesterday) and the timing is rite.
Old 05-03-2010, 06:28 PM   #4
jdmsoup
jdmsoup's Avatar
sorry i didnt word that right. lets see does it actually turn on and does the engine run? or does it just continue to turn over and over and never start?
Old 05-03-2010, 07:16 PM   #5
86.5supra
No I will not run. It just cranks and cranks and never starts
Old 05-03-2010, 07:38 PM   #6
jdmsoup
jdmsoup's Avatar
have you checked your fuses and your fuel pump to amke sure its getting fuel?
Old 05-03-2010, 11:04 PM   #7
Cameroonski
Cameroonski is on a distinguished road
Fuel pressure check said fuel checked out.
There are a lot of things that it could be. Try using the search option to find more information.
Pull one of your spark plugs, plug it in and hold it against the engine block while someone cranks the engine. There should be a spark. If not, it has something to do with your igniter or distributor or something.
But again, try searching it.
Cameroonski is offline   Reply With Quote
Old 05-04-2010, 12:55 AM   #8
86.5supra
Fixed it. I git in touch with a former master tech for Toyota who worked for the trd division. He told me it was probly the cam angle position sensor and to hit it with a wrench if it starts that's the problem. So I hit it and it started rite up and ran perfect. Thanks for everyone's suggestions
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
Supra won't start cmnetworx MKII Supra 2 07-31-2006 10:55 PM
87 Supra 7M-GTE/AT Engine cranks over but doesnt start... Supra-Boy MKIII Supra 7 03-15-2006 11:38 PM
