Old 05-02-2010, 05:19 PM   #1
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
Default Machine Work Costs
I have a 7mGTE with a blown head gasket at 126k miles. I have decided to go ahead and rebuild it. What is the average cost to have your normal rebuild stuff done. I am planning on having the head flattened for use with a metal head gasket and a valve job. (maybe three angle if i can afford it )
If anyone has, within the last year or two, has rebuilt a 7mge, I would much be much obliged if you could provide with me a breakdown of costs or an overall cost for everything. I know prices vary by area and such but none of the machinists in my area will give me an estimate up front. ( I live in Montana and everyone does V8s apparently )
So if you have it, a breakdown of what costs what would be nice but I'll settle for the overall cost.
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
Old 05-02-2010, 10:33 PM   #2
907mge
907mge's Avatar
I paid 500 to have the valves done, clean up ann smooth the ports and re check the shim/cam clearance.
Old 05-03-2010, 01:57 AM   #3
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
why so much man??? im paying 220 to get my head done by a mechanic who works strickly on race cars.
i was quoted at 900 for the engine being completely refurbished, but left open...
250 in gaskets for the entire engine, oil, and radiator fluid. Do the math friend.
Semper_Fi is offline   Reply With Quote
Old 05-03-2010, 02:21 AM   #4
907mge
907mge's Avatar
He spent quite a few hours with the dremel cleaning out the ports. Did a very nice job of a light port n' polish. I had started on my own but decided to let someone who knows what there doing to finish it. And also he heil coiled some of the exhaust manifol studs. Plus he is a very short walk from my house.
Old 05-03-2010, 02:35 AM   #5
Semper_Fi
Semper_Fi's Avatar
oh... makes sence. My guy is 30 minutes away... closest machine shop to me.
Old 05-04-2010, 02:22 AM   #6
P&P gets quite expensive. For general head work, tanking, valve stem seals, cam lash adjustment, valves lapped, dye inspection and vacuum testing will generally run between $200 and $400... it varies a LOT depending on where you are located as well as the skills of the shop.
head spacer or machine work? mattromey MKIII Supra 6 11-21-2009 02:26 AM
can you make these work with a 1jz swap..? JZA70dood Non-Generation Specific Questions 0 08-12-2009 04:17 PM
Where do i look for machine shop? Kevin MKIII Supra 1 05-15-2009 05:57 AM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
