Old 04-29-2010, 09:04 PM   #1
trevor217
trevor217 is on a distinguished road
Default Where to add RTV sealant to valve covers on 7M engine
I remember reading somewhere on these forums that the valve covers need a little RTV sealant when changing the gaskets. I've searched the site for a while and still don't have a clear picture as to where the RTV should go. If I recall correctly, it's near the #1 cylinder. Does it go on both covers? Which area does it go on?
Here's a pic from my photobucket account, if possible could someone copy it and circle the area to put the RTV, then post it here?
Hope the pic isn't too big!
Thanks!
Trevor
MKIII 7M-GTE stock
trevor217 is offline   Reply With Quote
Old 04-29-2010, 09:39 PM   #2
.Andrew.
.Andrew.'s Avatar
.Andrew. is on a distinguished road
I just rebuilt mine and to increase peace of mind put a very little amount around the front of each cover. In your picture go from bolt to next to Number 1 Cylinder.
.Andrew. is offline   Reply With Quote
Old 04-29-2010, 11:05 PM   #3
907mge
907mge's Avatar
In the tsrm it says to put seal pack up front next to the front cam caps. If I where you I would just put new gaskets in and make sure all the hold down bolt are tight.
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=56
Old 04-29-2010, 11:11 PM   #4
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
in project car they used a hefty amount. just fyi.
cvbikeguy is offline   Reply With Quote
Old 04-29-2010, 11:37 PM   #5
907mge
907mge's Avatar
good job posting the same thing
Old 04-30-2010, 02:49 AM   #6
trevor217
Thanks for the responses everyone! That answers my question perfectly.
Now if the weather holds up this weekend I will finally get these new gaskets installed...
Trevor
MKIII 7M-GTE stock
Old 04-30-2010, 03:02 AM   #7
907mge
907mge's Avatar
also if you can find them, you should get new washers(rubber and metal) since the ones on there now go totally flat
http://www.rockauto.com/catalog/raframecatalog.php
felpro makes a set of them for $15 i used
es72133 is the part number
Old 05-02-2010, 05:53 PM   #8
cvbikeguy
cvbikeguy's Avatar
lol 4 min. apart. i we must have been posting at the same time. my bad
engine oil sump sealant? nzskate MKIV Supra 1 04-08-2009 12:07 AM
Valve stem seals? Kuban MKIII Supra 9 03-27-2007 02:32 AM
