Old 04-26-2010, 05:38 PM   #1
kadinz
kadinz is on a distinguished road
Default high idle problem
i have found this out, something is holding the throttle up most of the time causing this high idle, i have checked all the springs and they all look good, except i havent checked the springs on the actual throttle. its not that stupid screw, any suggestions? i saw one of the cables goes to this box on the driver side...wish i knew what that was..
its not 100% consistant but about 90% of the time it idles at about 1200-1300 in drive and will go to(not always)2800 in park, most of the time 2000-2500 in park/neutral.
thanks for your help.
kadinz is offline   Reply With Quote
Old 04-27-2010, 03:53 AM   #2
Cruise control.
Sounds like the former owner couldn't get a good idle and started screwing with things. Make sure the idle adjustment screw on the top of the throttle body is closed all the way. Make sure the dash pot's plunger is depressing all the way. Make sure the cables both have a little slack and make sure the linkage isn't threaded all the way tight.
The TSRM does cover all of this, IIRC.
Old 05-04-2010, 01:50 PM   #3
kadinz
emkay, thank you! good to know thats the cruise control, my CC works very well.
theres this hose coming from the TB with some cylinder thing attached at the end of it, its a vacuum and its not connected to anything, do you guys know what it should be connected to?
Old 05-05-2010, 03:45 AM   #4
It's the restrictor for the dashpot. There should be a breather on one side, the other goes to a hose which connects to a metal canister on the TB.
Old 05-05-2010, 07:32 PM   #5
kadinz
im taking a picture of the TB in a min, im gonna post up what i think connects to what as of right now. i believe im missing something, there is still a leak and idk what it connects to..ill take a pic of that too.
Old 05-05-2010, 08:09 PM   #6
kadinz
http://i398.photobucket.com/albums/p...g?t=1273090104
vacuum leak like..under the intake
http://i398.photobucket.com/albums/p...g?t=1273090122
http://i398.photobucket.com/albums/p...g?t=1273090133
Old 05-06-2010, 04:16 AM   #7
[The first two are pictures of the actuator diaphragm for the ACIS system. It connects to a vacuum canister located further down just forward of the starter.
Wrong, as I said, the canister stays open to atmosphere... the rubber pert you have the hose stuffed into that's connected to the plastic canister is SUPPOSED to be a breather... nothing in it but some cotton filter medium.
Old 05-06-2010, 04:19 AM   #8
Try this:
http://www.cygnusx1.net/Supra/Librar...spx?F=1708&P=2
Old 05-06-2010, 01:59 PM   #9
kadinz
thank you very much i will get to fixin all this after work.
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Idle problem again. redmaro MKIII Supra 17 02-10-2007 07:42 AM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
