Old 04-21-2010, 10:23 PM   #1
2.5RHDsupra
2.5RHDsupra's Avatar
2.5RHDsupra is on a distinguished road
Default Supra stalls after sitting
Hey, My 1991 Toyota Supra TT seems to be acting funny.
ill get home from work at around 12 at night, and when i start the car up usually around 8 in the morning, its starts then idles under 1000 rpm.
then after about 10 seconds the rpms drop then the car stalls. i have to try to start my car about 3 times before it will not stall.
Any Ideas What Could Be Going wrong??
2.5RHDsupra is offline   Reply With Quote
Old 04-24-2010, 01:37 AM   #2
Potential problem areas that come to m mind are: ECU coolant temp sensor, Idle Speed Control Valve, cold start injector or the cold start time switch.
I'm moving this to the MKIII section where it belongs. Check the FAQ in that section for details on testing for diagnostic error codes and post back if you have any.
Old 04-24-2010, 04:55 PM   #3
2.5RHDsupra
Thanks Man, I checked my car and the coolant sencor was broken.
NICE Supra Turbo Sitting for Years ElTigre MKIII Supra 3 03-10-2010 02:39 AM
Supra sitting at Car shop, what should I do?? scalla1477 MKIV Supra 11 08-14-2007 08:12 PM
