Old 04-29-2010, 07:55 PM   #31
TripleC
TripleC's Avatar
You know i think my gauge is reading a little off but i have it set for 19 PSI but it regularly stays around 17 once the boost spike hits and levels out at higher RPM( i think it is reading 2 pounds less then what it is really at, so i may be closer to 20/21). I am only running 370 CC injectors but that will change before my next event. 440's in the gerage fendrs to roll, diffs to swap. i have a few projects ahead of my next event May 16th
Old 04-29-2010, 08:45 PM   #32
ReelBandit
ReelBandit is on a distinguished road
Do you have to go with special shocks when your car has TEMS? When I hit a bump its like I have hydraulics installed.
ReelBandit is offline   Reply With Quote
Old 04-29-2010, 08:47 PM   #33
TripleC
TripleC's Avatar
Yes when you have TEMS your suspension is adjustable. If it feels like you have hydro's then your shocks are toast. Springs could be a little old and bouncy too but it is mainly associated to the Dampening of your shocks.
Old 04-30-2010, 12:43 PM   #34
bryanf89
the tems was put there to make the car have a luxury ride...
@triple C, did you opt for the lexus AFM
Old 04-30-2010, 12:55 PM   #35
TripleC
TripleC's Avatar
I can get a bigger throttle body but i am pritty sure i have a MAP sensor not a MAF. i have not upgraded the stock throttle body.
Old 04-30-2010, 02:56 PM   #36
ReelBandit
Ok, so what type of shocks do you guys recommend? Standard gas shocks or....?
Old 04-30-2010, 03:57 PM   #37
TripleC
TripleC's Avatar
If you have tems i say keep it. i liked the way my car drove when i had my illumina II's and Tecikos. it just wasnt drift worthy. I had to much body roll. For the daily this setup was legit
Old 04-30-2010, 04:07 PM   #38
ReelBandit
I dont mean to sound repetitive, I would like to keep the TEMS, but I dont know what to do to fix the problem. Do I replace with standard shocks or do I have to find some that work with TEMS? If so where would be a good place to start looking for shocks that work with TEMS? Thanks for your help.
Old 04-30-2010, 04:12 PM   #39
TripleC
TripleC's Avatar
you have to find tems compatable shocks. they just have a top adjusting screw that the TEMS controlers actually twist. Look up TEMS when you search for Supra Shocks. i think the Illumina's are 450 from horsepowerfreaks. Look skip all this junk get some coilovers and be done with it. YOu will end up spending around 700 to get a new(er) setup when you could have spent 200 more and got yourself some coilovers and been happier. tems has 3 settings - Megans 32 ... you make the call
Old 04-30-2010, 11:56 PM   #40
bryanf89
yea ditch the tems if your loking to run your supra to the next level
TEMS Problem! 88 MARK3 Non-Generation Specific Questions 13 11-08-2018 10:41 PM
have some questions about 86-92 supra suspension jeremy_e87 Non-Generation Specific Questions 2 01-10-2007 11:53 PM
whats your opinion on the TEMS mad_dicer MKIII Supra 2 10-05-2006 02:17 PM
Suspension - TEMS - Coilovers Spudboy MKIII Supra 3 08-14-2006 02:33 PM
Strut bars for a 1990 N/A Supra with TEMS Paul Bernett Non-Generation Specific Questions 8 11-29-2004 02:07 AM
