Old 04-15-2010, 11:27 PM   #1
Life is Supra
Life is Supra is on a distinguished road
Default engine problems
I have a problem at cold start the rpms goes at 500 and than stals.When got to work temp.its fine and work ok at 800.Sometimes when I goes hard on the right foot,the car sut down when I let the aceleration pedal off?And I hear some knocking sound at head of the engine-can somebody tell me what to do I didnt check the codes...
Life is Supra is offline   Reply With Quote
Old 04-16-2010, 04:22 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
How about start by checking codes?
That's gonna give EVERYONE alot more useful info
Old 04-18-2010, 02:07 PM   #3
Life is Supra
I check the codes,and this is what I found-12,24,51.
Old 04-18-2010, 06:34 PM   #4
spoolmk3
spoolmk3's Avatar
spoolmk3 is on a distinguished road
12- rpm signal/ crank angle pulse/ cam angle sensor
24- intake air temp signal/ air flow meter
51- a.c. or neutral start switch--- is it a automatic?
motor swaps are a sad result of a non tuner!
If its a 7m / leave it a 7m
spoolmk3 is offline   Reply With Quote
Old 04-18-2010, 08:52 PM   #5
Life is Supra
thanks for info,its manual and I dont want to swap it just interest if the crankshaft of 7mge fit to 7mgte engine?And the air flow meter what to do with it?
Old 04-18-2010, 08:58 PM   #6
spoolmk3
spoolmk3's Avatar
the cranks will swap over but there are 2 different ones a 6m and 7m. the 7m is the best its fully ballanced from the 89 to 92 you can tell the difference because the 7m has counter weights (hammers) on every shaft and the 6m is like every other and should have 6m stamped on it.. for the afm bench test it or try cleaning it the air temp sensor is the little probe in front of the v shaped meter when you look in side
Old 04-19-2010, 12:08 AM   #7
vbryanv
vbryanv is on a distinguished road
let me know what you find wrong. i have the same issue as you. hard to start, starts and stall. bogs around 1500rpm and past 1500rpm no problem. no start after hot. replace throttle position sensor plugs and there are no vacuum leaks or coolant leaks. any suggestions
vbryanv is offline   Reply With Quote
Old 04-19-2010, 01:54 AM   #8
Green7mgte
Supra Forum Moderator
do not spray any sort of cleaner into your AFM.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-19-2010, 02:11 AM   #9
spoolmk3
spoolmk3's Avatar
my bad use a dry cloth..wipe away the buildup, as for the idle it might be time to have your injectors cleaned and balanced.
Old 06-13-2010, 10:25 AM   #10
Life is Supra
As for the idle and cold start problem I replaced the spark plugs and now I dont have a problem with idle....
engine problems darkOmini MKIII Supra 4 06-06-2010 03:34 PM
1982 supra-celica engine problems. plz help bjm007 MKII Supra 2 11-14-2009 09:30 PM
Sup Guys, total nub having some engine problems with my MKIII... Mr.Supra857 MKIII Supra 3 11-14-2006 06:37 PM
engine problems thewhitedevil69 MKIII Supra 3 03-07-2006 12:17 PM
Problems With New engine. lilsmitty MKIII Supra 1 10-29-2005 07:43 AM
