Old 04-06-2010, 11:10 PM   #1
nailhead432
nailhead432 is on a distinguished road
Default valve noise
I've been expriencing a couple of differenet tapping / knocking noises. The loudest noise happens during start up but goes away when the oil pressure increases. The other noise sounds a little like a lifter tapping.
So, today I took the cam covers off and checked the clearances on my valves. All of the intake valves had .010 clearance except the furthest one back on 4 and 5. Both of them had .011 clearance. All of the exhaust valves were at .012 clearance. Would only 2 of the valves being out only .001 be enough to cause such a dramatic noise?
nailhead432 is offline   Reply With Quote
Old 04-07-2010, 02:08 AM   #2
The tapping, if very light may just be the injectors.. we've got loud injectors. The knocking sound may be due to a misfire or the early sign of impending rod knock.
Old 04-07-2010, 03:48 PM   #3
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
If you really get the knocking just at start up, you've more than likely a rod bearing about to go. My supra was doing this recently until i spun a bearing, and it sounded like it was coming from the top of the motor...such a sad time.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Wind noise near driver mirror BillW MKIII Supra 3 12-17-2009 05:09 AM
engine makes knocking noise.. 88WhiteMKIII MKIII Supra 4 06-10-2009 09:09 PM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
