Old 04-05-2010, 12:41 AM   #1
rohin02
rohin02's Avatar
rohin02 is on a distinguished road
Default Brakes question, feedback needed.
so i just had my front rotors replaced and about a week after my brakes started to squeak, now my mechanic said its the brake dirt that builds up and it takes some time for the rotors to wear in or something like that i just need some feed back?
rohin02 is offline   Reply With Quote
Old 04-05-2010, 12:52 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
What kind of brake pads do you have on there? I.e. semi metallic, ceramic, organic...
Old 04-05-2010, 01:23 AM   #3
More often than not it's due to the material the pad is made out of; the failure to install or replace the pad shims; or glazing of the pads.
Old 04-19-2010, 04:24 PM   #4
Read up: http://www.stoptech.com/whitepapers/...otors_myth.htm
Ask any *well educated* brake tech and they'll point out that you can tell if a rotor is warped by simply spinning the spindle with the caliper on and measuring the clearance. Since learning this I've watch mine and my friends' cars rotors I always assumed were warped never were. An engineer friend was quick to point out that similar metals are used to transport and pour molten metals... and those containers go a long time before warping.
Old 04-28-2010, 01:31 AM   #5
rohin02
rohin02's Avatar
i took my pads off they were totally done so i replaced em with new ceramic ones and they are perfect now thanks guys
Lost my brakes today... wtffffff Kevin MKIII Supra 4 06-04-2009 05:50 PM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
Question on brakes 87 Supra MKIII Supra 7 11-01-2007 02:44 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
Brakes 5M Vs. 7MGTE panda-supra MKII Supra 3 03-22-2006 09:07 AM
