Old 04-03-2010, 03:39 PM   #1
SupraShogun
SupraShogun is on a distinguished road
Default The Newb Speaks
I like to say, that I'm bless to be in here. Now the asking begins, OK here's my story, I was shopping around on Ebay for a Supra MK3 and i have come across some with bent valves, now after seeing those i saw a MK3 with 155.xxx miles on it for 1,800 and it said it ran and needed a lifter job done to it and it had no key. So i called up the guy and said I'll buy it for that much we made a agreement on it and the deal was on. I came down to pick up the car and before that i called a transporter to ship the car to me. To my surprise (ha ha) the wheels locked up and the shipper call up is boss and called me to see if i wanted to let them play around with it to get it unlocked, now what i knew was he had been playing around with it before i gave him to do so. So I'm STILL here in IL, after 5 days waiting on the part for the Lock cylinder that he messed up by putting a screwdriver in it. I checked the oil and it was almost bone dry and the owner said that he started it up 2 month's ago and it ran with a tapping sound. Now i don't know what to happen when i turn on the car can anyone help me????
Thank you,
SupraShogun.
ITS A ROD KNOCK LIFE FOR US, ITS A ROD KNOCK LIFE FOR US. In the words of the great one that said them.
SupraShogun is offline   Reply With Quote
Old 04-03-2010, 05:24 PM   #2
907mge
907mge's Avatar
When I bought mine it was about 2 hours away, I drove it home my self. No more that 10 min into the trip it blew a hose and overheated. Luckily I had it towed back and the seller replaced the hose.
So if I where you I would have it towed back because without knowing the exact history of the car any number of things could go wrong.
As far as starting it you can make sure the oil is filled and start it but should shut it off right away if there are any weird noises. Youtube is a good place to see the videos of the weird noises the 7m can make.
Good Luck.
Old 04-03-2010, 06:59 PM   #3
WTF??? The 7M is a non-interference motor... finding just ONE with bent valves is highly unlikely, much less many.
Old 04-04-2010, 02:45 AM   #4
Exactly what I was thinking as I was reading this thread. I've lost a timing belt on a 7MGTE and the bottom end spun several times without even a single tick from the engine.
IMO, 1800 is overpriced for a supra that has no key, no oil, and locked up wheels. Before I buy it I would go buy some oil and start it up on the spot to find out exactly what that sound is, whether it's top end or bottom end.
Old 04-05-2010, 06:31 PM   #5
SupraShogun
*update* OK Clutch is out unless its the lock system the car has killing it, otherwise the cutch has no feedback what so ever..... My god man its been 7 days that i was here. Can anyone give me a price on fixing that clutch? Or its the systems messing with it?
Old 04-05-2010, 08:17 PM   #6
Clutchmaster cyl have fluid?
Old 04-05-2010, 10:53 PM   #7
SupraShogun
Yes just topped it off with break fluid and its still dead.
Old 04-05-2010, 11:16 PM   #8
907mge
907mge's Avatar
I'd say don't buy it, if that is still possilble.
If you are stuck with it i would rent a uhaul and a trailer to get it back. That way you can take your time and do all the repairs the right way.
Old 04-05-2010, 11:46 PM   #9
SupraShogun
Yeah the car is mine now.... I was thinking that way until i saw the prices of u Haul. $568+$281= Not worth it. What I'm stuck on is it said it needed a lifter job???? What does that mean in the land of 7MGTE. Let Lord be with me.
Old 04-06-2010, 12:01 AM   #10
The 7M uses shims on top of buckets (aka lifters)... even with severe wear the valve train should operate well enough that minimal losses will be noticed at medium loads. If a shim managed to get kicked out it'll eat the cam like a fat guy at a wedding buffet. Excessive vlave clearance may allow the cam lobed to actually contact the shims causing heavy wear and a light ticking sound... a spit shim should like a little monster eating matchbox cars.
As for the clutch master, did you bleed the line? What is the clutch doing?
Newb to the site. Have a 91 Supra thats in need of repair. Introducing Myself J.Rod MKIII Supra 11 01-02-2010 07:09 AM
Newb to the site. Bought a 87 Yellow Supra Today. Introducing myself AaronCDC MKIII Supra 48 12-22-2009 11:42 PM
supra newb overheating vdesign MKIII Supra 13 06-27-2008 05:09 PM
Hey Hey Im a NEWB with an 89 Turbo Mdunaway MKIII Supra 1 02-26-2008 02:51 AM
Newb with newb questions 1jzToyota MKIII Supra 4 11-07-2006 01:24 PM
