Old 03-28-2010, 03:45 AM   #1
Arlo444
Arlo444 is on a distinguished road
Default Exhaust Recommendation for 90' 7M-GTE
First let me say these forums have been a great source of valuable information. I am in need of exhaust recommendations for my daughter's 90' 7M-GTE turbo. A "friend" replaced the stock down pipe with an aftermarket 3" pipe and removed the front cat. From there it's stock to the rear cat then cat back is 3" HKS. The problem is it fails NOx inspection here in Texas. I've confirmed no vacuum leaks, checked EGR, VSV and recently performed tune up. Need to get it road legal but still want the performance. Suggestions?
Arlo444 is offline   Reply With Quote
Old 03-28-2010, 05:12 AM   #2
Green7mgte
Supra Forum Moderator
hi, welcome to the bord.
NOx is caused by high combustion temperatures. The EGR reduces the combustion temperature by mixing inert gasses into the air/fuel mix.
retarding the timing will decrease the NOx. You may want to even retard it more than spec by a couple degrees or more. Then after inspection, put it right on spec.
Also fill up with premium. High octane burns slower and should help too. (Less chance of detonation)
Maybe try one step colder spark plugs too. This reduces the chances of a hot center electrode causing pre-ignition.
A lean fuel mixture also burns hotter and may increase NOx. If one injector is spraying lean, that could cause it to burn hotter in that cylinder.
If all else fails, weld in a second universal catalytic converter (in series, not parallel).
(taken from http://answers.yahoo.com/question/in...4113417AA6uoEz
best of luck
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
Does the exhaust manifold need to come off to replace head gasket? BillW MKIII Supra 1 10-02-2009 12:19 AM
Exhaust Cat Fitting Bill UK MKIII Supra 4 06-15-2008 11:32 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
