Old 03-26-2010, 09:33 PM   #1
supraspaz
supraspaz is on a distinguished road
Exclamation oil being pushed out of everywhere!
hello all noble supra guru's. also if this was in the faq i'l sorry i didnt see it, but i am haveing an issue where oil is being pushed out of all areas of the engine (valve covers, oil pan, cam cover and now behind the distrubitor!) could this be a vacuum issue? had to replace my starter because of it being defective! yay advanced auto parts for it being a free replacement ! so as to that being said i have the intake body apart up to the 1st intake assembly. had the head apart to replace bhg. had no leaks before so now after i have this problem that is why i'm leaning toward the vacuum lines getting crossed. it is a 87 7m-ge and i had replaced ALL the vacuum lines ( just some info to give you background on work done) or could this be a sign of something bad on the horizon... thank you for your time in this matter. Gary.
supraspaz is offline   Reply With Quote
Old 03-26-2010, 09:47 PM   #2
97SupraTT
97SupraTT is on a distinguished road
wow, that is bad. First thing i would have though of was something to do with venting the valve cover, but this is obviously worse then that. Keep me posted, id like to learn too. Good luck.
97SupraTT is offline   Reply With Quote
Old 03-27-2010, 06:45 AM   #3
Green7mgte
Supra Forum Moderator
are you sure its leaking through all those above mentioned? or could it be slinged around due to the fan- air - w/e else.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Motor Dies When Gas Is Not Pushed joemoua MKIV Supra 5 07-07-2008 05:07 PM
