#1 |
Supra Forum Moderator
christ. you should be trying to run 500 hp or better with 20psi..
f it. if you got the cash go bigger. if you can find 4" the whole way out. "note" I did not look at his current specs. I am not saying running 20psi is warranted for his current build. just stating my opinion.
92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#2 | |
my goal is around 500hp-550hp for this summer
*87 Supra Turbo* Rebuilt 7mgte w/ Forged Internals P&P Head Brian Crower Stage 2 Cams Greddy FMIC HKS BOV soon to be either 61-t turbo or 71mm turbo other than that stock |
#3 |
im sure there might be some minor things that take their tole by using a huge exhaust.. gass milliage or what have you. I THINK the only downfall would be back pressure. but that's for n/a's so nothing for turbo's to worry about.
#4 |
well I been reading up on another Supra forum site 2day and they were saying will lose low-end TQ but will gain top-end HP and can run more boost due to the better flow and Turbos work better with less back pressure, back pressure is only needed for n/a cars
#5 |
yea i know.
#6 |
The only downside I could think off would be clearance; if you have lowered the car, 4" exhaust might bottom out easily. Just a thought.
87 N/A 5spd BHG, soon to be gte with r154 |
#7 |
yeah that sure is true mine is lowered and my 3in cat has a few scrapes on it already
#8 |
the cars sits on stock springs and 17" rims with 245/45/R17 front and 255/45/R17 rear
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Exhaust for 7MGE | XtreeX | MKIII Supra | 19 | 03-25-2010 01:39 AM |
| Does the exhaust manifold need to come off to replace head gasket? | BillW | MKIII Supra | 1 | 10-02-2009 12:19 AM |
| exhaust question (not in exhaust faq) | sd88supra | MKIII Supra | 21 | 11-28-2006 10:52 PM |
| Exhaust Size??? | BP907MGTE | MKIII Supra | 0 | 06-09-2006 02:51 AM |
