#1 |
already did...so the new cap and rotor didnt help really...anything else...i fixed the tps sensor so im all ears!
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
Have you actually tested the signal from the TPS? Test the voltage coming from Vs, should be around .5 closed, 3.5 full open and should sweep steadily between.
grumble...... Post more info about your car, add it to your profile or better yet put it in your sig........ /grumble Where was I... Is this a GE or a GTE?
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
its a stock 7mge...no havent tested it yet...so vs to ground im guessing?
#4 |
Yeah, to ground... the TPS signal line it VTA, not Vs... I had already moved ahead in my head with the other big possibility:
With a N/A the problem is more likely to be a flat spot in the VAFM's Potentiometer. Test pin Vs there for consistent voltage while opening the vane. Test both though, they are both wear components... no idea why everyone buys used ones, they do have a limited lifespan.
#5 |
so guess what i did...i was testing the afm and found that it was bad. Then like a curious cat i decided to pull the actual sensor out. Didnt know it was connected by short wires and pulled two of the circuits clean off the circuit board...So now the car wont start. Anybody have an extra afm for sale or anything. i dont feel like paying 130 for a new one and a four day wait
#6 |
Supra Forum Moderator
get your self over to supra mania stat and check out there for sale forum.
I see them there all the time. mostly for turbo's tho. but you might get lucky.
92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#7 |
oh well had to resort to advanced...
| Thread | Thread Starter | Forum | Replies | Last Post |
| no throttle in gear | weol66 | Non-Generation Specific Questions | 0 | 07-26-2008 01:04 PM |
| lost of power at full throttle?? | peedamonkee | MKII Supra | 4 | 01-08-2008 05:50 AM |
| Jdm Throttle Body | Luvs2slide | MKIII Supra | 1 | 07-24-2006 07:15 AM |
| Throttle response | f00g00 | MKIII Supra | 1 | 04-13-2006 12:57 AM |
| throttle body | 87supraguy | MKIII Supra | 0 | 02-17-2006 02:40 AM |
