Old 03-20-2010, 01:16 AM   #1
fasteddy5000
fasteddy5000 is on a distinguished road
Default Mysterious hose from back of motor
Does anyone know where this hose goes Thanks, ED.Click image for larger version
Name:	heater hose Question.jpg
fasteddy5000 is offline   Reply With Quote
Old 03-20-2010, 07:08 AM   #2
On a left hand drive supra, that is not a hose. It should have a cap on it so that coolant doesn't leak out.
Since this thread is MKIII specific, I'm moving it to the MKIII section
Old 03-20-2010, 02:08 PM   #3
fasteddy5000
Default response to strange hose
Thanks man. The guy I got the car from, stuck a spark plug into a hose and clamped it on there. It's been rackin my brain because I couldn't understand why the hose was there. Thanks, it must be some kind of drain hose then.
Old 03-20-2010, 02:36 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
The design of the metal pipe is used on left hand drive and right hand drive vehicles. On left hand drive as btwilson86 said it should be blanked off with a rubber cap or on later models metal cap. On a right hand drive Supra that end of the pipe is used to connect to the heater matrix via the firewall and the cap is used on the metal pipe on the right of the diagram. In other words all the connections are swapped around depending if its right hand or left hand drive.
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
couple of questions about my 7MGE motor SDK MKIII Supra 2 12-13-2009 07:26 AM
Sm Vac Hose Under Accordian Hose Chromemoly MKIII Supra 3 07-03-2009 01:19 AM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
