#1 |
Ok this is what I found.. So is it truly going to be better this route.. I can get this from jdm engine corp. for $2100. Engine, transmission, everything.. Is this truly going to be better for me. I also want to maintain balance on the car. If you say somthing about doing a 1jz then please let me know about the weight differences and if I will need anything... EXTRA.. I mean is it a direct swap, you know.. Somthing simple. I have a guy who could do the complete swap in 2 days for $600. Remember folks, I want direction.. So help me out please.. I will keep looking for more info too.
Used Imported JDM 7M-GTE Turbo 3.0L V6 Toyota Supra 1986 - 1992 Engine & 5 Speed Transmission Swap ! Your Swap Includes The Following:
#2 |
478 vs 463
So there is only a slight difference in the 1jz vs 7mt.. No worries there.. Now my only question is.. Direct easy swap, or do I need some extra parts that will make my mechanic want more $$$ for complication..! |
#3 |
Here is what I found for the 1jz. Since it is imported I would need a few extra things huh? I was reading about needing some mounts for the transmission. Also needing some other stuff because the engine is imported.. Is this a good idea folks? Going to 1jz like this? They want $2000 for it..
Used Imported JDM 1JZ-GTE Twin Turbo 2.5L Toyota Supra 1989 - 1993 Engine Swap ! Your Swap Includes The Following:
#4 |
![]() Toyota Racing Development Join Date: Apr 2007
Forget the 1JZ swap... ESPECIALLY if you're paying a mechanic to do it! It is not what I think of as a terrible swap, but it is involved.... some people do think it's miserable though.
Definitely go with a 7M-GTE swap, but you're right, you don't want to just drop it in either... it should be carefully inspected and anything which needs attention should be taken care of. There's a lot more to turboing a 7M-GE than you seem to think. Get the GTE, rebuild it and drive with the GE until the new engine is ready to be swapped in.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#5 |
Yes i'm sure it would be easier to put in a 7mgte, but if your going to have to pay someone to do everything be prepared to pay. I've always found it more fun to learn and do it yourself. Plus always remember the person who will care the most about about your car is you. And if you think it looks too complicated you could put in a 350 with a carb, can't get anymore basic, plus a nice v8 rumble. Just kinding about the 350 even though it has been done.
#6 |
Cre, all this sounds great! I am truly getting excited now!! So with the 7MT sitting at the shop. What type of things besides what we find will need to be done; should we do?
I mean as far as the head gaskets and such. What are some good ones that I can get that will be more durable. What sort of things should I have done to the engine to help keep cost down of having to re-pull the engine for. Such as better cooing system, or bigger turbo (I'm sure you won't need to do a pull for this but I am just saying) Let me know what you think. I will be going with the 7MT, will this be a easy swap? Yes, I will have the matching transmission with the engine. |
#7 |
Yep thats the way to go more power without proper control. I think thats the reason why less and less supras are around these days. And also becareful if it gets wrecked don't expect the insurance company to write a high check for a 20+ year old car. As far as the rebuild alot of people put in a metal hg and arp head studs but the the block and head both have to be machined. Also alot of clean up is in order.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1990 Supra Turbo -Any Good!!? | ukferrari | MKIII Supra | 3 | 12-13-2009 09:13 PM |
| what do you think of this setup? | Jareduhhhh | MKIV Supra | 4 | 02-19-2009 10:38 AM |
