Closed Thread
Old 02-24-2010, 10:29 PM   #1
turbosupraIII
turbosupraIII is on a distinguished road
Default knock sensor rewire help!!
do I need to rewire both of the KS or just one? Also if it is both do I have to run 2 wires to the ecu meaning make 2 rewires seperatley on 2 on 1 wire and run 1 wire back to the ecu.
turbosupraIII is offline
Old 02-24-2010, 11:41 PM   #2
mirage83
As long as you're doing one you might as well do both. And I wouldn't tie them together, but that's just me.
mirage83 is offline
Old 02-24-2010, 11:58 PM   #3
turbosupraIII
aight cool but i can put the grounds together though?
Old 02-25-2010, 12:37 AM   #4
mirage83
Think so, but make sure you've got a good ground for it. You using coax?
mirage83 is offline
Old 02-25-2010, 06:50 AM   #5
Rewire both.
Yes, you may run the grounds from each to the same place.
cre is offline
Old 02-25-2010, 07:55 AM   #6
This is what you need to do: http://www.supras.com/06/techcenter/display.php?QID=69
A separate coax wire for each sensor. The shielding may be grounded at the same location; Although, I would ground the shielding by the sensors to the nearest intake manifold stud.
cre is offline
Old 02-26-2010, 02:06 PM   #7
turbosupraIII
what about the ecu i tap into the wires i understand that but i also have to ground again by the ecu like the same thing by the KS?
Old 02-26-2010, 04:06 PM   #8
Yes, ground both ends.
cre is offline
Old 02-26-2010, 06:43 PM   #9
turbosupraIII
ok i did the rewire and the light is off.... i drove the car and its still doing the same thing wont let me go past 2500 rpm if i floor it, but if i baby it, it lets me go?? any idea what this can be????
Old 02-26-2010, 06:44 PM   #10
turbosupraIII
also the cel did not come on
Closed Thread
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
Rod Knock kewlcoconut MKIII Supra 20 01-13-2006 08:39 PM
