Old 02-16-2010, 02:22 AM   #4
I replied to you in one of your other threads about the heater:
http://www.toyota-supra.info/forums/...html#post78879
If you are getting heat part of the time the VSV I mentioned that may be intermittently failing, there may be air in the system, or the heater core may be thoroughly clogged and in need of a chemical back flush. Top off your coolant and try bypassing the valve I mentioned above as they're the easiest things to do.
Coolent hose leak. probably heater core Green7mgte MKIII Supra 7 11-26-2009 04:43 PM
Heater hose locations suprabahamut MKIII Supra 4 12-16-2008 10:07 PM
Heater Core Outlet Hose - need help xTomKx MKIII Supra 6 11-21-2007 04:59 PM
Heater Hose routing. scooterh72 Non-Generation Specific Questions 3 05-12-2006 03:17 PM
Where is the heater core inlet hose? Brady Montz MKIII Supra 0 04-21-2005 06:11 PM
