Old 02-17-2010, 06:07 PM   #11
kadinz
kadinz is on a distinguished road
Originally Posted by supradaddy0803 View Post
Personal opinion after hearing that noise, take out a 45mm pistol, walk up to the car slowly from behind as to not scare it. Then do a nice double tap on the engine its dead. You also have to realize that with that noise being as loud as it is may not be the top end. Metal transmits sounds so it could be anywhere. I think you have the right idea replacing it will be cheaper than rebuilding. With the prices you showed there are cheaper places to find engines I know a guy in Dallas that has a 7MGTE for like 400 bucks ECU and everything.
cheaper? 350 for the engine, i dont need the ecu or anything, he has it i just dont need it.. than i am having him put the engine together with a metal headgasket, whole engine replacement is 700bux with labor out the door, thats cheap as FUCK
kadinz is offline   Reply With Quote
Old 02-17-2010, 07:23 PM   #12
$400 for a complete GTE engine and supporting electronics? $700 for a complete swap? You guys are just begging for it aren't you? These aren't bargain prices, these are run away screaming prices... the $400 I could understand if the person sold or wrecked their car and now just wants all the crap that's been sitting in the garage for the past 4 years gone... but $400 in labor for an engine swap and $350 for the engine?? Um, no. There's a lot of labor involved and three times more if it's done right.
Old 02-17-2010, 10:56 PM   #13
mirage83
Key words there... if it's done right.
Sounds to me like somebody is trying to get rid of a piece of junk. I mean seriously, what EXACTLY did the PO do to "freshen up" that engine? Hose it down with Febreze?
Old 02-18-2010, 02:36 AM   #14
hell for a couple 100 more you could get an ebay engine.. probably more luck with that. but then again if the mechanic is a personal friend of yours that you known for a long time and trust.. i might do it. but not without insurance of some sort. is this a case of "you get what you pay for" or is it a friend helping another friend?
Old 02-18-2010, 10:18 PM   #15
supradaddy0803
supradaddy0803's Avatar
You would be correct the guy wrapped the rear end around a tree and pretty much everything in the front is in good shape. He just wants the grim reminder gone so 400 bucks is what he told me. I drove his car before and it ran strong boosted fine.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 02-19-2010, 12:57 AM   #16
shoot do it. if it ends up being a crapper.. you could probably make your 700 back by parting it out.
Old 02-20-2010, 12:15 AM   #17
97SupraTT
97SupraTT is on a distinguished road
I know im posting a lil late, but after reading the first few posts, i though that maybe the cam gears might have jumped a tooth on the belt and causing the valves to be off. not sure if im way off or not. but trying to help. hope all goes well.
97SupraTT is offline   Reply With Quote
knocking around 2000-3000rpms Suprafreak MKIII Supra 11 03-24-2009 06:45 AM
Hard Engine Knocking 86SupraMan MKIII Supra 10 09-14-2007 05:39 AM
funny knocking sound on 7mge Jeff_5_7 MKIII Supra 11 09-09-2007 01:22 AM
Help with knocking on front end supra96 dini_the_owl MKIV Supra 8 09-03-2006 10:24 PM
knocking block, want to build solid bottom, what should i use alcbarrios MKIII Supra 1 04-14-2006 04:16 AM
