Old 02-07-2010, 06:08 PM   #1
hopesanddreams47
hopesanddreams47 is on a distinguished road
I've seen that type of thing multiple times in other cars the surging is almost in every case that i have delt with ended up being vacuum, or a tps. have you put your finger over the hose to see how much vacuum its pulling?
hopesanddreams47 is offline   Reply With Quote
Old 02-08-2010, 06:01 AM   #2
Codelicious
Codelicious is on a distinguished road
Here are some pictures. Hope these will help you guys help me! lol
--This one is on the left side of the engine bay (passenger side) and comes out by the Fender, I have no idea what it goes to. The other end isn't connected to anything..
--This is about in the middle of the engine bay and had nothing attached to it so we just put a cap over it for now..
--This is just below the first picture I posted, if I remember correctly the hose on the other side leads to the canister.. we put a cap on it because nothing was connected to it..
Started the car up today and it ran just fine.. it only revs itself up on occasion. Hopefully finding the right spots for these will fix it.
Codelicious is offline   Reply With Quote
Old 02-08-2010, 06:42 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Can't quite see what I'm looking for in pic 1.
IIRC, the line in pic 2 goes to the BVSV (two pronged vacuum valve on the thermostat housing, they're common to break so yours may be non-existent at this point). The line in pic 3 that runs off of the MAF Sensor should connect to the other end of the BVSV. If there is no BVSV, you may be able to hook the MAF Sensor directly to that nipple on your intake, but then there would be no regulating when the unburnt vapors from your charcoal canister are allowed in your intake.
Old 02-08-2010, 07:45 AM   #4
Codelicious
Thanks for the reply.. My friend and I looked at the chart thats on the hood and we figured that it would go to the BVSV but we looked for it and we are unable to find it..
Is this the BVSV...?
If so mine is broke... I'll have to buy a new one.. do you believe that this will fix the reving issue?
Old 02-09-2010, 03:21 AM   #5
btwilson86
Super Moderator
btwilson86's Avatar
Yup, that's a BVSV. It at the very least should help a little, although I can't say for sure if it'll completely fix it.
Actually, since you capped off the lines it probably won't change the revving. It will, however, help your evaporative emissions system work properly.
Since there are quite a few vacuum lines on the car, I'd suggest spending some time running through the engine bay and checking that everything is hooked up properly. I had to do this on my first 87 (N/A), and it really didn't take that long.
Click here for the vacuum routing diagram (note that this includes all the lines connected to the engine, but not all of them in the engine bay). Thanks to green7mgte for the link in another thread.
Old 02-09-2010, 04:23 PM   #6
Cyto
Cyto's Avatar
Cyto is on a distinguished road
Check the rest of the vacuum lines. Here is the diagram.
http://www.cygnusx1.net/Supra/Librar...spx?F=1708&P=5
If you haven't bookmarked this site go ahead and do it. It has saved my ass on many occasions lol
Proud owner of a 1988 Toyota Supra Turbo, 105k Miles, and great condition.
I might have to sell it to help pay for school so here's the link.
http://www.toyota-supra.info/forums/...html#post72357
Cyto is offline   Reply With Quote
Old 02-09-2010, 06:11 PM   #7
The hose coming out from the fender is the washer fluid line.
The revving thing is most likely a defective, stuck or disconnected ISCV (Idle Speed Control Valve): http://www.cygnusx1.net/Supra/Librar...ction=FI&P=106
