Old 01-24-2010, 05:21 PM   #1
gteduck
gteduck is on a distinguished road
It will alter where your power is made in the rev range.
the higher that is the more HP, BUT it will take longer before it tries to separate your head from your shoulders. I'm not sure if u can do it with a factory EMS ???
if you do it , get it done properly, otherwise you might end up with a big ass paperweight .
gteduck is offline   Reply With Quote
Old 01-24-2010, 09:05 PM   #2
bryanf89
im still not clear about it...can u give me an in depth explanation
Old 01-25-2010, 02:10 AM   #3
gteduck
the cam gear basically advances or retards the timing on the cam ( opens the inlet valves earlier or later in the engine cycle ) this inturn will give you power lower or higer in the rev range, depending if you move it to the plus or minus side on the gear. zero is standard timing. it can be a simple way to gain power,but there are trade offs. I had mine done when i first put the 7mgte in my mk2. BUT i have a microtech EMS witch was tuned on a dyno via a laptop. it let the engine rev out more giving me about 274whp , great on open roads but annoying in traffic. At low rpm in traffic it was not as smooth. It tended to surge a bit while holding accelerator steady. No problem on the gas ,or of it ! But i was always in traffic going to and from work so it got annoying . So next time i had it serviced i had them set it back to fairly standard timing, witch dropped my power to 234whp. still running 15 pd boost with both tunes. but made it alot smoother at low steady revs .
Old 01-25-2010, 02:18 AM   #4
bryanf89
so turning towards a positive range will advance my timing allowing more power in higher rpm's but not allowing a smooth engine timing in lower steadier rpm's? I'm assuming turning it towards the negative range will retard my timing allowing more power in lower rpm's to allow quicker acceleration but losing out on top speed?
Old 01-25-2010, 02:49 AM   #5
gteduck
it's the other way, advance for low end and retard for top end. retarding it lets it rev higher than you normally would be able to, you can tell the differance quite easy once you drive it , i loved holding it at about 3000 rpm in third and then bury my foot . My diff is a 4.1 so it really would launch hard and the extra revs meant i didn't have to shift as early. IT WAS FUN!!!!
Old 01-25-2010, 03:04 AM   #6
gteduck
EMS = engine management system, the little computer or box that controls the injectors and look's after firing the plugs, you air fuel mixture ,all that sort of crap. you know the shit that makes it go! LOL
i'm not sure if the mapping needs to be altered that's all maybe you should ask your mechanic. Im only a dumbass engineer!!! lol
i can machine an engine ,assemble an engine, but i'm the last prick you want to tune your engine!!!! LOL
Old 01-25-2010, 03:17 AM   #7
bryanf89
ok gteduck let me see if i got this correct....tuning the cam to a positive range will retard my timing allowing my engine to achieve higher rpm thus producing more hp in higher gears but the trade off is not having smooth timing on low steady rpm and tuning my cams to the negative range will my advance my timing allowing for quicker acceleration in lower gears but losing out on top speed and power in higher gears...is my knowledge on this correct?
lol if there was thing i want to do to my supra is definatly rebuild the engine give that baby a new heart a modified heart that is lol
Old 01-25-2010, 02:30 AM   #8
gteduck
I'm not sure if this is possible with a Factory EMS cause i never had one on this particular engine. If u find a mechanic that can do it for you , he should know if its possible. whatever you do don't just slap it on by yourself and hope it works. It just might do more harm than good. have you done your gasket and put in arp head studs yet? i had mine done by a friend who tunes hi performance turbo cars for a living. it does make the car go hard thou when done right. You'll have a smile on your face for a month. till u get used to it ,then you'll want more.
hope it helps!
Old 01-25-2010, 02:44 AM   #9
bryanf89
Is my conclusion on cam timing correct? y wouldnt it be possible on the stock EMS? my mechanic is well known in the field he could take a car apart and put it back together lol.
by the way what does ems stand for...i heard of the ECU but EMS? i know it cant be electronic modulated suspension lol
honestly i dont know if the car got a new gasket or head struts. i bought the car from a guy that worked in a dealership and he said he set the turbo to 12psi im sure he changed the head gasket at the very least unless he wasnt pushing it
Tags
fidanza cam gears, timing
Aftermarket gauge cluster? djblanco MKIII Supra 2 09-26-2011 02:15 AM
Best bang for your buck aftermarket supra parts j_moy_08 MKIII FAQ 86 01-21-2011 06:38 PM
I have an aftermarket exhaust.... Aghhh redmaro MKIII Supra 1 11-20-2006 05:38 PM
Rear end gears. TxSpeedBoy Non-Generation Specific Questions 0 02-08-2006 06:12 PM
