Old 01-13-2010, 08:08 AM   #1
1_BAD_MK3
1_BAD_MK3's Avatar
1_BAD_MK3 is on a distinguished road
Question boost lagg
i fixed my car all i needed was a new battery but now it lags boost when u step on the gas it goes but then it bogs and it starts backfiring why
1_BAD_MK3 is offline   Reply With Quote
Old 01-14-2010, 05:33 AM   #2
Check for diagnostic codes... If you're back firing you're running crazy rich or the timing is off... may be indicative of a knock sensor issue.
Old 01-14-2010, 09:05 AM   #3
1_BAD_MK3
1_BAD_MK3's Avatar
how do i check all that and were is the knock sensor located
Old 01-14-2010, 05:22 PM   #4
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
I just saw your other thread about this matter... After replacing the turbo did you check the spark plugs for fouling and replace them if needed? Also, if the former turbo was dumping too much oil a lot may have accumulated in the IC and piping which will need to be thoroughly flushed out or it may foul new plugs.
Old 01-15-2010, 01:31 AM   #5
1_BAD_MK3
1_BAD_MK3's Avatar
yeah i got new spark plugs checked everything and i found out what was making it lagg it was the main relay
Old 01-16-2010, 07:31 AM   #6
two-step-n
yeah sounds like the knock sensor i had the same thing happen to me i had to rewire the knock sensor to the ecu bad stock old wire
Old 01-16-2010, 07:44 PM   #7
1_BAD_MK3
1_BAD_MK3's Avatar
where is the knock sensor located
Old 01-17-2010, 03:51 AM   #8
Green7mgte
Supra Forum Moderator
simple search
knock sensor mk3 supra
http://www.toyota-supra.info/forums/...locations.html
in our very own forum!
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 01-18-2010, 04:24 AM   #9
The N/A knock sensor is actually closer to the middle than indicated in that diagram; It's not in the same location as the GTE's rear sensor.
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
Wont accelerate under boost, misfires, backfires, and wont idle Andrew - turbo a MKIII Supra 1 07-24-2009 01:39 PM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
