Old 01-11-2010, 08:05 AM   #1
SDK
SDK is an unknown quantity at this point
well i have a Cressida with the 7mge motor. Thats why i said that and not the model. Engines would take the same amount no matter what car it was in. thanks that helps!!!
SDK is offline   Reply With Quote
Old 01-11-2010, 08:52 AM   #2
Unless it's been modified. I was just kidding around, my system takes a lot more than stock.
Actually there could be differences due to the different oil pan.... but not enough that I'd sweat it.
Old 01-11-2010, 01:19 PM   #3
Green7mgte
Supra Forum Moderator
first time oil change.. Add.. check, add check.. add check.. write it down. I have a running sheet were I record all maintance and mechanical work I do. ez referance for how much oil I added last time.. or sometimes I even mark it on a peice of tap to the inside of my door. don't worry about it if you add to much, just drain some out, since you have it on jacks anyhow. Do not run your car with too much oil. I did this once on a 89 sunbird, I made it 1/4 mile down the road when my gauges went fish eyed and my car shut off. My 7mgte takes at least 5 quarts
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
7mge R154 Manual Trans nnate1228 MKIII Supra 0 03-28-2009 05:59 PM
1JZ-GTE Engine with 7mge Stock Fuel Pump joolhamdi MKIII Supra 1 06-10-2006 10:29 AM
7mgte AFM on a 7mge boogum7 MKIII Supra 1 04-07-2006 02:12 AM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
