Old 01-04-2010, 09:31 PM   #1
suprabahamut
Default Tire noise
I wanted to make sure before I drive a lot, I have searched also but found nothing. I use to have 225/55/16 tires on and I bought some used tires for the time being until I buy new parts for the front end alignment, they are 205/55/16. After I bought the tires it sounds like growling a loud noise constant, and kind of thumping when braking. I think it is my suspension because it is old and creaks a lot before the used tires, or alignment problems because it wore my other tires out. They look fine no plugs and are not old, but maybe out of balance. The guy told me there is some new guys working there. I just wanted to know what you guys think? Is it something I should be worried about, or just leave it for now. After I buy new front end parts I am going to buy better tires so it is just temporary.
Old 01-04-2010, 09:57 PM   #2
You do know there is a pretty big difference in the overall circumference of those tires compared to your last...
Given that the tires are used it is not at all unlikely that uneven wear on them might be emphasizing other existing problems. I don't recommend running used tires, but I do understand. Did I understand that you haven't even had them balanced?
Old 01-04-2010, 09:59 PM   #3
suprabahamut
They were balanced and have new wheel weights on them, but there is new people working there some kids.
Old 01-04-2010, 10:34 PM   #4
Originally Posted by suprabahamut View Post
They were balanced and have new wheel weights on them but there are new people working there some kids.
In that case I suspect it's more likely the different treadwear emphasizing other problems. Check for play in the suspension member bushings, ball joints and tie rods.
That's where I'd start anyway.
Old 01-06-2010, 08:53 PM   #5
suprabahamut
I found out it is the wheel bearing, it they start to make that much noise how much time do I have left about? And what will happen if I don't replace it in time will it cause a major problem? I don't have the money right now, but I will have it soon. What are some symptoms I need to look for before I need to park it till it gets too bad.
Old 01-06-2010, 09:16 PM   #6
Drive REAL slow. If it's to the point where it's making noise I'd be hesitant on driving it... I'd rather not guess on what you may be able to get away with.
If you're mechanically inclined you could pull the knuckle, buy the bearing from NAPA or the like and just take the knuckle to a shop to have it pressed in. This can be done for a LOT less than having all the work done by a shop. The shops around here only charge $20 - $30 for pressing the bearing out and the new one in. I don't know how much the new one will cost.
Tire and Wheel fitment Q&A 1988gte MKIII FAQ 124 03-16-2013 02:53 AM
Wind noise near driver mirror BillW MKIII Supra 3 12-17-2009 05:09 AM
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
