Old 01-02-2010, 10:40 PM   #11
Androidrc
Androidrc's Avatar
Androidrc is on a distinguished road
Default thanks
u know what i helicoiled and restudded the exhaust manifold the other day and when i was all done i forgot to plug the AFM back in when i first started it up. it was a week ago but it WAS unplugged for a minute or 2. im gunna put my coat on and go outside for a bit. THANKS ALOT for all the help and information ill let u know what i find.
Androidrc is offline   Reply With Quote
Old 01-02-2010, 10:59 PM   #12
You really NEED to get the oil out of the galley, especially since you've pulled the plug wires out with the oil in there... it WILL cause misfires.
Old 01-03-2010, 01:53 AM   #13
Androidrc
Androidrc's Avatar
Default it's 9 freaking degrees out
o no i pulled them off the coil but i agree it needs cleaned out. the 5 minutes i looked at it tonight haven shown me nothing but tomorrow i can put it in the garage and see. im thinking there is probably a broken wire somewhere in the harness that runs by the thermostat housing considering all of the sensors in question run by there. that or a bad afm. but until then thanks again for the help.
Old 01-03-2010, 06:24 AM   #14
Androidrc
Androidrc's Avatar
Default research
well in the morning im gunna check the plugs and for openings or shorts in the harness but i have a bad feeling. after looking at the tsrm troubleshooting guide, all for codes have one possible fault in common, the ECU. ill keep my fingures crossed and hope i just have to repair a wire or something but it's not looking good for now. even just the word ECU sounds expensive.
Old 01-03-2010, 08:08 AM   #15
The ECU is a possible source for EVERY code... it seldom is the problem... unless you've been doing some creative wiring.
Old 01-03-2010, 05:13 PM   #16
Androidrc
Androidrc's Avatar
Default mostly solved
ok well i went out and pulled my plugs. 4 out of the six were DRIPPING WET with what smelled like dirt mixed with burnt oil. it does burn some so that makes sense. i cleaned the plugs off and removed any corrosion from the wires and reinstalled everything.......RUNS GREAT. better than ever. next month (ill be away with the army for a month) im going to get after it really good and do valve cover seals, oil galley plug seals, plugs, wires, and an oil change. thanks for the help i appreciate it very much. ill let u know if anything starts up again
Old 01-03-2010, 08:45 PM   #17
Oil in the galley has nothing to do with burning oil (unless both are a symptom of a severely cracked head). The oil got on the plugs when you pulled them. Plugs come out and oil and dirt pour in.
I'm glad the problem was a simple one!
7mgte front clip supraman121 MKIII Supra 4 05-31-2007 01:27 PM
