Old 12-20-2009, 08:29 PM   #1
mean gene
mean gene is on a distinguished road
Default need help with fog light bulb changing
have an 88 markII turbo and need to change out bulb-- does this unscrew or what
thanks
mean gene is offline   Reply With Quote
Old 12-20-2009, 08:42 PM   #2
im not sure if you can reach it from the front but the whole assembly is removed from behind the bumper...
Old 12-20-2009, 09:48 PM   #3
1988 is a MKIII, not MKII. The foglight housing for the '88 has a phillips screw on the inside edge of the chrome trim which is accessible from the front of the car (no digging around under or behind the fixture. Remove the screw, the trim will then hinge out and pull off. then you can slide out the glass and metal lamp housing. Pull the rubber boot off the back and the rest should be obvious. When replacing the bulb DO NOT TOUCH THE GLASS of the new bulb.
Old 12-22-2009, 02:59 AM   #4
mean gene
Default mark iii fog lamp
obvious maybe but mine is old and has a fair amt of corrosion-- does this sucker unscrew or what after the rubber damn comes off
thanks in advance for your help
Old 12-22-2009, 03:15 AM   #5
Only one screw involved. After you get the housing slid out and pull off the boot, there's just a spring clip and the bulb comes right out.
Old 12-23-2009, 01:18 PM   #6
mean gene
Default fog light thank you
got it-- thanks
Merry Xmas to all and a happy new year
gene
check engine light & bulb light, what? nosuprayou MKIII Supra 2 12-19-2009 09:15 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
Indicator lens/ changing bulb colin172 MKIII Supra 5 09-17-2006 03:53 PM
Tail Light Changing? newbsupra MKIII Supra 2 05-21-2006 04:07 PM
light issue kewlcoconut MKIII Supra 5 11-24-2005 04:28 AM
