Old 12-13-2009, 06:38 AM   #1
suprakillz
suprakillz's Avatar
suprakillz is on a distinguished road
so when i go and pick up my fuel filter (the right one this time, i hope) they should know what washers i need right?
i need to find a garage where i can work on my car.. the parking lot just is not going to cut it any more. especially now that is cold as hell, and it gets dark so fast.
Kansas city ks. 89 supra,mk3. 7mge manual. after market head lights and fog lights. stock engine for now.
suprakillz is offline   Reply With Quote
Old 12-13-2009, 07:01 AM   #2
The dealership should have the washers, if not take the old ones to some of the other local auto parts stores... shouldn't be difficult to find a couple the right size.
In a pinch you can improve your odds or reliably using the old ones if you anneal them with a torch and then make sure the two faces are perfectly smooth by buffing with some 600 grit sandpaper... I don't recommend this as I'm not accepting any liability if you do and you end up having to pull the damned thing back out because it leaks.
Old 12-13-2009, 07:12 AM   #3
suprakillz
suprakillz's Avatar
Yeah.. i'll just look for them.. i don't have the tools to go trough all that, nor would i be willing to do it either.
Old 12-13-2009, 09:22 PM   #4
86.5 7MGE
86.5 7MGE's Avatar
Default Check this place out!
A good place to look at when searching for automotive bolts, nuts, washers, and screws if you can't find them at the auto parts store is Ace Hardware if you have one you can go to. They carry more options than Home Depot or Lowes when it comes to Automotive Hardware.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 12-15-2009, 05:29 AM   #5
suprakillz
suprakillz's Avatar
yea. that place has all sorts of uncommon things.
Cobra Guys dissin Supra TT MagicStick MKIV Supra 92 11-26-2007 03:06 AM
What is involved (all parts, labor, price) in auto to manual swap??? the t3d MKIII Supra 1 01-18-2007 03:01 AM
