Old 12-11-2009, 09:50 PM   #21
I don't think it's really worth it to replace the oil cooler unless you go the distance and replace the stock pressure based system with a thermostatic one.
As for the transmission cooler, I thought it was 180? but I don't know a whole lot about automatic transmissions. Anyway, the bit I was still waiting to hear back about was if the oil cooler needed a thermostatic bypass (or if it SHOULD have one added) or if the transmission has an internal bypass.
Old 12-12-2009, 09:09 AM   #22
Okay, a thermostat isn't needed (not for the tranny cooler). As long as you mount the cooler somewhere with good air flow you do not need a unit with a fan. The fan will be needed if you place the cooler in a location with poor air flow such as behind the fog light.
I can't emphasize enough that you need to plan the placement and routing very carefully... it can be a pain. Have you thought this out already? I'd like to know what you've come up with.
Old 12-12-2009, 07:16 PM   #23
916MKIIIx2
Right now im working on putting in a custom front bumper bar as opposed to the heavy stock one, bolting that up today then I have to map out the new space ill have. But from my original planning I was planning on mounting the tranny cooler right to that bar and have it up front about 3-4 inches infront of the intercooler, the oil cooler will be put in its stock position, if anyone can think of a better spot post it up.
Old 12-13-2009, 07:07 PM   #24
That sounds fine, I prefer having oil coolers behind the IC for added protection myself.
Off Topic: I was just thinking the other day about getting an aluminum bumper support built for my car.... heh, cool. How are you building yours? Is it steel or aluminum? Any numbers on how much weight you've managed to cut off?
Old 12-16-2009, 07:34 PM   #25
916MKIIIx2
Going with aluminum, but from what my instructors told me and from what I looked up, you don't even need the bumper bar, and I believe I managed to get out about 30lbs from the front taking out the big ass blast bard and brackets that held it. New bar is about 10 lbs, only problem with the alumi bar is it didnt really weld well to the frame work so we had to setup a bolt in system which added a little bit of weight. I'll post some pictures soon as I can.
Old 12-16-2009, 07:58 PM   #26
Well, that's the kind of advice you get from asking a knitting instructor about car stuff. I'm sorry, but either you weren't listening or they thought you were talking about a 'track only' vehicle. That bar could be one thing which would have saved your life in a severe front end collision. It's not just a matter of your driving skills but that of those you share the road with as well. Also, if you remove or modify (in such a way as to not meet legal requirements) safety devices which are required by law you give at fault parties a way to back out of paying for damages they do to you and your car... or at least you give them a way to fight the thing to the point of never paying you a dime.
Wait... "weld to the frame work"... what bar are you talking about here anyway? The bumper (the actual monstrous beast which absorbs impact is a bolt in assembly... at least on my car and the one from which my new bumper cover was pulled.
Post pictures, I'm lost now.
Old 12-16-2009, 10:44 PM   #27
916MKIIIx2
Aye stock is bolt, I wanted a stronger hookup but ended up using the stock bolt up... But what I meant about the bar was you don't need it for the frame to stay sturdy, but yes it does save your life ;p Which is why instead of ripping it out I had a lighter one made! Moved the battery to the back as well, you'd be amazed at how different just those two things made the front of the car feel, more response less understeer.
Old 01-16-2010, 04:58 PM   #28
916MKIIIx2
Alright the radiator got here last night and I went to bolt it on... Turns out I need some custom clamps somewhat like the ones used on the Koyo 1JZ radiator swap... anyone got instructions on that or something? ;p
Old 01-18-2010, 04:30 AM   #29
I only had to make two or three clips from some 1/8" x 3/4" aluminum stock from Home Depot. They're only around 2" to 3" long and just have a bend in the middle to offset them... it was really easy. No pics though, sorry.
Old 01-18-2010, 04:45 AM   #30
916MKIIIx2
Thanks, I just needed the info you just stated... I know you had posted somewhere else already, just didn't find it so thanks again!
Tags
radiator
Anyone compared good 4" to good 5" or 6" spkrs in the front? wdb Car Audio and Alarms 4 07-29-2010 09:57 PM
Cost effective? Need some major advice here! Devoted2Supra MKIII Supra 6 04-13-2009 02:35 PM
Who has the best quality stuff? ozsupra Car Audio and Alarms 51 12-24-2008 11:29 AM
