Old 12-06-2009, 03:31 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
Default cam cap torques...
They're 14ft/lb (20Nm) right?
Just wanna make sure 'yota ain't lying on these ones too!
Oh, and what's the best thing for cleaning cylinder head gasket surfaces? I've got it feeling smooth to the fingernail test but I can still see little tiny dots of composite on there & I ain't happy...
Old 12-07-2009, 06:47 AM   #2
No changes on those, just do as the TSRM says... and in the right order.
Old 12-08-2009, 02:40 PM   #3
MA70-3.0GT
MA70-3.0GT's Avatar
Cool, at least they got that right! What about the H/G residue cleaning?
Old 12-08-2009, 10:11 PM   #4
I don't know about the availability over there, but here you can get "gasket remover" made by Permatex. It helps quite a bit (VERY nasty stuff). You may polish the deck surface with some ultra-fine sandpaper to finish the job (1200 grit or higher). Even with a grit that fine you need to make sure not to over work any one area... I recommend wrapping the sandpaper around a piece of plate glass to use as a make shift lapping plate.
Is there any pitting on the deck?
Old 12-15-2009, 05:46 PM   #5
MA70-3.0GT
MA70-3.0GT's Avatar
Oops, missed this!
Anyways thats cool, I've got most of the crap off by carefully scraping with a flat scalpel blade but there was just a few little marks left where the blow occured & round the edges of the combustion chambers.
No pitting or any nasties like that, in fact the head looks like new except for those slight marks & on measuring has only had under 10 thou skimmed off over the years. It's even still true so a little rub over to clean it up & we're away.
EDIT-: that's once I've found a HG for the right money anyhow, the one I found for ?11 (that's supposed to say 11 pounds not 11 question marks!!!) on Ebay is an option but I'd rather pay a bit more for one I can look at & buy in person, just not the ?60 the local factor wants!!! yeah I'm a stingy
Old 12-15-2009, 08:48 PM   #6
True or otherwise if you're planning on installing a metal HG you need to make sure it is amazingly smooth. Are you going to be installing a metal HG or an OEM style composite?
Old 01-29-2010, 03:07 PM   #7
MA70-3.0GT
MA70-3.0GT's Avatar
Wooo it's good to be back online..... only had mobile phone internet since before christmas & boy does this site look different on a 1.8" screen!!!
Anyways, what with one thing and another I'm STILL waiting on enough spare cash to get the H/G but once that miracle finally happens it's gonna be composite yeah, I'm not planning on doing much with the motor especially now I'm more skint than usual. Recession sucks azz...
Old 01-29-2010, 04:15 PM   #8
kamikazemkiii
kamikazemkiii is on a distinguished road
You get what you pay for, headgaskets deff. one of those things i wouldnt cheap out on.
kamikazemkiii is offline   Reply With Quote
7M-GTE Head torques on stock bolts... MA70-3.0GT MKIII Supra 2 11-07-2009 04:58 PM
