Old 12-05-2009, 06:19 PM   #1
bryanf89
Default RWD Benefits??
What are the benefits over FWD?
Old 12-05-2009, 11:06 PM   #2
Busted Knuckles
Busted Knuckles's Avatar
Much better weight balance, and burn-outs in FWD just look lame.
When you accelerate, the weight shifts to the rear of the car. FWDs lose traction as the weight shifts away from the drive wheels. RWDs gain traction on acceleration.
Power drifts with FWD actually leads to an understeer, where the car will push off the curve. Very dangerous in performance driving situations.
There may be a few others, but that's my 2 sec drill.
Old 12-05-2009, 11:25 PM   #3
bryanf89
Default Excellent
thanks for your insight
Old 12-06-2009, 02:43 AM   #4
Krem
The way I've always seen it is FWD will pull the car while RWD pushes it.. When you have a heavy object on wheels, is it easier to pull it? or push it? IMO, puttin your back into it and pushin goes a lot further than breakin your back pulling... I've also always been superstitious that FWD cars are more likely to break their motor mounts as a rear wheel drive and the RWD might twist with torque when the mounts are broken, but a FWD car w/ broken mounts looks like the engine is ready to jump right out if you slam the gas too hard..
The only practicle use for FWD over a RWD that I've seen or experienced is snow driving... I'd rather drive w/ a FWD in the snow than a RWD simply cause it's better grip. A FWD will turn the direction the front wheels are pointed because the momentum is also the point of turning. A RWD car will also turn towards the direction the wheels are turned but might not follow the direction the wheels are turned as the rear end generates the momentum while the front turns...
Old 12-06-2009, 03:47 AM   #5
bryanf89
Some good advice pointed out by Mr. Krem. I live in manhattan the heart of nyc. I wont be driving my baby in the snow shit i dnt even drive when its raining. Too many crazy ppl out nd the supra is too precious to risk it.
Old 12-06-2009, 04:03 AM   #6
Okay, that's just flat out awesome!
RWD is worse in snow? Nah... I really can't say that I have a huge preference except that I do prefer RWD for slick roads; But only if it's got the right tires for the weather.
Old 12-06-2009, 06:13 AM   #7
bryanf89
lol it sounds good but manual in the city ehhh
