Old 01-27-2010, 11:19 PM   #241
cvbikeguy
cvbikeguy's Avatar
No rtv...
What problems am I looking at? And I did buy new bolts for the cam covers so I might have warped them?
Old 01-29-2010, 06:25 AM   #242
cvbikeguy
cvbikeguy's Avatar
Cre?
Anyone?
Old 01-29-2010, 07:53 AM   #243
Well, did you over torque the covers? If you did you can check for warpage by holding them against a piece of glass... no biggie. After you reinstall (and put RTV in the right place here too) if you have issues with leakage then you've most likely crushed the rubber seal... and before anyone tried to argue that you can't crush rubber, go look up the shore durometer scale... I'm sick of arguing about stupid shit (not at all directed at you CV).
As for the RTV on the timing plate... you're going to leak oil by the water pump and below the alternator... if it gets bad enough it will soak and ruin the timing belt.
The location where RTV is REQUIRED is shown on these two pages:
(1st picture)
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=55
(1st picture)
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=56
Additionally, there is an order you SHOULD use when installing the valve covers. Tighten the two middle bolts 1/2 the torque value, then tighten the inner bolt toward the front, then the outer bolt toward the rear, then the outer toward the front, then the inner toward the rear... then in the same order torque the rest of the 22 INCH lbs.
I am sorry... I thought you were following the manual with all of this.There are two ways to seal the leak at the timing plate: pull the head or pull the lower timing plate... both entail approximately the same amount of labor, but the head is the one you're familiar with... and the head is the safer bet... downside there is you'll need a new HG. By pulling the timing plate you can slide it off, load in a lot of RTV on ALL of the connecting surfaces and then try to slide it in without pinching the HG thus preventing the timing plate from mounting without a gap... I've done it successfully, but I don't recommend it.
I'll add that I think it's unlikely that ou warped the valve covers... still, you should check them just in case.
Old 01-29-2010, 08:34 AM   #244
I've been through the timing plate thing on two of these cars, including my own not both my fault although mine was). It's not the worst thing that could happen and pulling the head back off isn't so bad... not since everything's been off recently and the process is fresh in your mind.
The leaks at the lower timing plate are generally very steady, but slow. You can get by for a good amount of time before tackling it. Sometimes it won't start leaking right away either, but that doesn't seem very common. Unfortunately, this is a common oversight another common source of leaks here is machine shops not cutting the block deck with the timing plate installed thus making the timing plate taller than the block which holds the head up at the front.
I feel bad man. Nothing worse than forgetting one little thing only to find out it just may bite you in the ass in a big way... but seriously, don't freak... it shouldn't be leaking so much as to prevent you from driving the car for a month or two until you're ready to swap the HG... and the HG WILL be easier to swap the second time around... hell, maybe you'll the one lucky SOB for whom it doesn't leak.
Old 01-30-2010, 04:40 PM   #245
cvbikeguy
cvbikeguy's Avatar
Unhappy
sooo i have been following the tsrm. i did notice the part about sealing the timing cover but i thought it was nothing. and honestly didnt quite understand. the rtv goes behind the rear timing plate (between the block and the timing plate? or since i can take the head off i can rtv on top of the timing plate? i did have the machine shop shave the plate along with the block so they are flush.
and for the timing covers i can just rtv in the corners as shown in the picture? also are you using stock bolts with the philips heads or did you get replacement bolts? i have new bolts but i couldnt find grommets like the original.
thanks so much for the help cre. i think this is exactly whatmy problem is. besides changing the distributer o-ring and figuring the electrical for my oil pressure sensor.
Old 01-30-2010, 06:40 PM   #246
The RTV does go on top of where the plate and block meet. Put down about a 1/4" bead.... I'm pretty sure mine leaked because I put it on way too thin.
Get new grommets from Toyota or another parts shop if they have them... definitely use them. I'm using hex bolts with a flange head along with rubber/copper grommets I found at a specialty hardware shop. If you really want to make sure they stay in place you may add a drop of temporary thread locker to each of the bolts.
Still no oil pressure readings?
Old 02-06-2010, 01:15 PM   #247
cvbikeguy
cvbikeguy's Avatar
heyyy sorry for not having an update. i have classes just for a few weeks and i wont be able to resume for a little. the car is currently sitting in shame.
ok sooooooo. just to triple, double, quadruple check. all i need to do is take off the head. not the rear timing plate.
then put a thin bead on top in those two spots where the timing plate and the block meet.
hmmmmmmmmmm
since im going to be unable to work on it im also going to see if i can order new copper washers, no 3 valve cover, and a few other things.
Old 02-06-2010, 07:39 PM   #248
Yes, pull the head to seal that area... it's just as much work the other way, harder to reassemble and you're likely to scrape the RTV out from where it needs to be when you put the plate back on.
Did you go with a metal HG or an OEM style composite HG? If you used a composite HG it needs to be replaced.
Don't forget the RTV at the #1 cam caps when you reinstall the valve covers.
I'd install new cam seals and new valve cover seals if you haven't already done so.
Old 02-19-2010, 09:40 PM   #249
cvbikeguy
cvbikeguy's Avatar
heyyy sorry im back from school. i had training for 2 weeks for my plumbing. i already have new seals and i have the no. 3 cam cover, copper washers, misc bolts and head gasket on the way. what area on the cam covers should i rtv? man im so surprised that its such a big deal to rtv that tiny space on the timing cover.
Old 02-20-2010, 04:40 AM   #250
I linked to the TSRM pages where it shows where to RTV both timing cover and the valve covers a few posts up: http://www.toyota-supra.info/forums/78100-post243.html
Yeah, we don't use a lot of RTV on these engines but this engine's a bitch when you forget it.
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Picking up my 89 tomorrow 8uwav6 Show n Tell 2 03-31-2008 08:08 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Supra Noob checking in from Florida PalmCoastMk3 Non-Generation Specific Questions 1 12-23-2005 05:08 PM
Supra Newb Just checking in Razor Non-Generation Specific Questions 1 12-21-2005 04:15 AM
