Old 11-10-2009, 11:52 PM   #1
.Andrew.
.Andrew.'s Avatar
.Andrew. is on a distinguished road
Default 1989 Supra N/A : GTE> Need Help
Hi everyone and thank you for all of your help with all of the other problems i had a couple years ago. I come back to you all after being a hardcore supra owner now i face a new challenge. My supra has a N/A motor and after getting a new GTE with ecu and harness is there going to be any issues when trying to swap/convert it over to turbo? Also I am going to do W58 swap while everything is stripped out of car... so thats part of the equation. This is the only forum I stay on and am hoping you allcome through
.Andrew. is offline   Reply With Quote
Old 11-11-2009, 12:57 AM   #2
You need: Oil cooler (preferably a custom full-flow setup as the stocker is garbage), the same year engine harness and ECU as your car is HIGHLY recommended as the dash harness also has to match, clutch, drive shaft, intercooler and piping, ALL electronics (AFM, Igniter, coil packs), lines for the R154 clutch, motor mounts from your original engine if they are a different style, GTE fan and fan clutch are highly recommended.... I'm sure there are a few other things that I'm forgetting, I'll post back if I think of anything.
Old 11-13-2009, 10:36 PM   #3
.Andrew.
.Andrew.'s Avatar
Thanks Cre,
I got everything you said with a W58 trans tho and electric fans. For that igniter does it have to be off of a 7mgte. also is there any little parts that go for the GTE_(electronics, switches, relays, valves) My supra is an 1989 and the turbo motor i got is from an 89 :-) so the harness and ecu are most likely good ++
Old 11-16-2009, 04:21 AM   #4
camdiddy
camdiddy is on a distinguished road
Hey, not trying to hijack tha thread Andrew but i have a related question.
Cre...I have a 86.5 that i want to swap a gte motor into, since no turbos were made in 86.5 will a 87 or 88 harness work without many issues? Thanks
camdiddy is offline   Reply With Quote
Old 11-16-2009, 04:33 AM   #5
Originally Posted by .Andrew. View Post
Thanks Cre,
Yes, it requires the GTE igniter. The relay's and fuses are largely the same but you'll also need to swap in the injector resistor pack from a GTE as the 89 N/A didn't use one. The 89+ N/A's used high impedance injectors where all the rest of the MKIII's used low. Trying to use low impedance injectors on a high impedance ECU will destroy either the injectors or the ECU. I can't think of anything else right now.
The dash harness is pretty much the same as the 87 and 88.... you should be just fine there. It's the same deal as swapping a 87 or 88.
Old 11-16-2009, 07:01 PM   #6
.Andrew.
.Andrew.'s Avatar
[QUOTE=cre;74951]Yes, it requires the GTE igniter. The relay's and fuses are largely the same but you'll also need to swap in the injector resistor pack from a GTE as the 89 N/A didn't use one. The 89+ N/A's used high impedance injectors where all the rest of the MKIII's used low. Trying to use low impedance injectors on a high impedance ECU will destroy either the injectors or the ECU. I can't think of anything else right now.
Thank you again Cre. Looking for the igniter now. Im going to see if i can get the high impedance ones from RC. The 7MGTE i bought has the fuel rail w/ injectors too. so if i cant afford the RC will those work?
Old 11-16-2009, 07:04 PM   #7
.Andrew.
.Andrew.'s Avatar
Dont trip camdaddy we should all be on this forum to give/take what we know and help others learn. I think its retarded when people try and get "forum territory"...
Old 11-16-2009, 07:10 PM   #8
Don't even bother looking for high impedance injectors. The GTE electrical system (ECU and harness) is built for low and low is the most common. Just get the low and make sure you get the resistor; You can get the resistor from any 7M-GTE or any pre89 7M-GE vehicle.
Old 11-17-2009, 03:52 AM   #9
camdiddy
haha thanks man, i aint trippin
Old 11-17-2009, 06:39 PM   #10
.Andrew.
.Andrew.'s Avatar
Ok thanks cre do you know where the resistor is located in the car? Im having a hard time with toyota trying to explain to them. (toyota of glendora.......)
What's the value of a 1989 Toyota Supra? MysticKnight MKIII Supra 14 02-13-2011 05:26 PM
1989 Toyota Supra Supra_Newb MKIII Supra 3 10-06-2009 08:09 PM
New to forum...1989 Bright Red Targa Turbo Supra Virgin, Pics included. whowouldfigga Show n Tell 3 03-13-2008 07:47 PM
Mint 1989 supra found. Need quote on re-torque whowouldfigga Non-Generation Specific Questions 2 02-05-2008 01:57 PM
