Old 02-24-2010, 07:28 PM   #11
supraluver4life
supraluver4life is on a distinguished road
ok so you said something about changing out the transistors in a ge tach to make it work like a gte. so i canged the cluster again cuz i wanted a volt meter in the cluster instead of a boost gauge (just got a set of delphi gauges ) and the tach doesnt really work so can you run me through how to make it work?
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 02-25-2010, 07:17 AM   #12
Just changing resistors... How about a pic?
Name:	Tachometer conversion GE to GTE.jpg
Old 02-25-2010, 09:02 PM   #13
supraluver4life
thank you. when i rev the engine the gauge doesnt really move. but when i turn on the lighhter plug and heater while rolling ddown the windows, the gauge works, is this because of the resistors?
+300rwhp
Old 02-25-2010, 11:19 PM   #14
I've never experimented with swapping gauges just to see what happens when the wrong one is used, I do know that people generally report very odd behavior on top of the fact that it is a mile off when it does move.
Old 02-25-2010, 11:37 PM   #15
supraluver4life
so i just swaped out the gauge circuitry from the gte tach to the ge tach so its a ge tach with the gte circuitry and wouldnt you know it...
it works
thank you for the help. i would have never knon that the resistors and such are different. thank you for the help in solving the problem
+300rwhp
Tags
cluster, gauges, instrument
