Old 11-06-2009, 06:17 PM   #1
Rob1
Rob1 is on a distinguished road
Default 87 turbo add on
Does anyone know where i could pick up a turbo add on kit for a 1987 toyota supra, including turbo manifold intercooler piping the whole works and about how much it would cost??
My work in progress!!!
1989 toyota supra turbo targa top 7mgte, Five speed left hand drive.
Rob1 is offline   Reply With Quote
Old 11-07-2009, 09:22 PM   #2
brad88supra
brad88supra's Avatar
brad88supra is on a distinguished road
http://www.2kracing.com/Product/1982.html
1988 N/A Supra, 5 speed, Targa top, Tems
brad88supra is offline   Reply With Quote
Old 11-08-2009, 07:42 PM   #3
Despite what they say, that's not a kit for converting a N/A. It has a lot of part you need for any conversion but there's a whole lot missing. Unless you're running a fully rebuilt 7M-GE that turbo's a bit much (the only one I ever worked on grenaded and slaughtered the #2 cylinder of the MKIII it was on after about 10K). The kit does not include a manifold or wastegate actuator so you'll need to source those. You MUST add an oil cooling system (don't go with the stock GTE setup, it's horribly ineffective). You'll also still need to figure out your oil supply (not too hard) and provide a nice BIG drain for the turbo. Most drain to the oil pan, you have to pull it and add a return location; there's a bolt blocking a port on the oil pan that's used on the GTE for the return for the cooler, this is too low for a turbo oil return do NOT use it. You're also going to need a rising rate FPR (whether a stock GTE FPR or an aftermarket adjustable), larger injectors (GTE injectors are fine, but if you use used injectors get the professionally cleaned and flow tested!), a stronger fuel pump. You may need to reduce your spark advance as well.
My recommendation... do a GTE swap.
