Old 11-04-2009, 05:17 AM   #7
Supra_Sicc
Supra_Sicc is on a distinguished road
Start here: http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=12
A bad ground can cause crap performance but it won't kill a coil.
thanks for the link i was just about to go look for one. Im thinking it shorted out. the 3 hot wires coming from the harness going into the coil pack were exposed completly at the splice. so i re heat shrinked it. but all my coil packs are dead. i got power going to them but nothing coming out. -_-. anyone have a coil pack for sale?
1989 Toyota supra. 7mgte swap
Hks ssqv blow off valve/Tokico Blue Suspension/Greddy Turbo Timer/ARP Head Studs,torqued to 85lbs/Titan Motorsports Metal Head Gasket/RPS Max Pressure Plate/Toyota Turbo Clutch Disc/1 PC Aluminum Driveshaft.
I need help with my turbo timer!!!
Supra_Sicc is offline   Reply With Quote
coil pack help dieseltech24179 MKIII Supra 1 11-30-2008 11:32 AM
coil pack grounds gomezmk MKIII Supra 1 01-01-2008 05:01 AM
Distrubtor Question kidsusukigsxr Non-Generation Specific Questions 5 02-09-2007 10:45 PM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
