Old 11-03-2009, 05:13 AM   #1
Supra_Sicc
Supra_Sicc is on a distinguished road
Default Coil pack issues!!!!
my two new coil packs are dead. I had them on and fired right up. drove it around and hit a big bump.and then the dreaded stall...i immediatly checked the coils... and no fucking spark on the two new ones. i noticed my ground was broken(did it fry them? and if so why just those two and not my old one. maybe a split line shorting the two out?)and now gonna try indvidual grounds on each pack.. and if they are fried i got a year warrenty on em.
And boy today was the first time i got to drive the beast(bought the beast saturday not running)no spark to the two coil packs on their and a broken ground.... same situation. but the motor pulls smoothly up to 4.5 grand( didnt wanna push it) this is the first car ive bought. i guess you get what you pay for.1400...
Supra_Sicc is offline   Reply With Quote
Old 11-03-2009, 05:43 AM   #2
The 7M-GTE runs a "wasted spark" setup. Which cylinders are dropping out on you? It's quite likely the igniter or the wiring in between is the problem.
Old 11-03-2009, 06:13 AM   #3
Supra_Sicc
it is 1-6-3-4 are the ones dropping out. which fucking sounds like the wiring inbetween .
1989 Toyota supra. 7mgte swap
Hks ssqv blow off valve/Tokico Blue Suspension/Greddy Turbo Timer/ARP Head Studs,torqued to 85lbs/Titan Motorsports Metal Head Gasket/RPS Max Pressure Plate/Toyota Turbo Clutch Disc/1 PC Aluminum Driveshaft.
I need help with my turbo timer!!!
Old 11-03-2009, 01:32 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
Hi, I've got running issues too but there's no need for language like that mate. Supra's are a pretty cool car & I'd imagine a fair few kids read this forum as a result... Not that I'm offended in any way (you wanna hear the mouth I've got on me) but there's no way it can just slip out when you're typing it.
Old 11-03-2009, 02:29 PM   #5
Supra_Sicc
ok well im alittle frustrated. i love the car handles and runs great. when it does run but it keeps llosing power to the first 2 coil packs and leaving the third one(or first one off the harness) with spark. so maybe its in the splice were the other 2 keep loosing power or bad connection
Old 11-04-2009, 01:52 AM   #6
Start here: http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=12
A bad ground can cause crap performance but it won't kill a coil.
Old 11-04-2009, 05:17 AM   #7
Supra_Sicc
thanks for the link i was just about to go look for one. Im thinking it shorted out. the 3 hot wires coming from the harness going into the coil pack were exposed completly at the splice. so i re heat shrinked it. but all my coil packs are dead. i got power going to them but nothing coming out. -_-. anyone have a coil pack for sale?
Old 11-04-2009, 07:21 PM   #8
2jzmaestro
2jzmaestro is on a distinguished road
i found some coil packs on http://www.toyotapartszone.com
they are pretty cheap. might as well buy new ones and if anythign return them haha jk
2jzmaestro is offline   Reply With Quote
Old 11-05-2009, 03:57 AM   #9
Supra_Sicc
Default woot new coils
thanks for link, im assuming i fixed the problem. does it make sense that my coils could have shorted out due to the exposed power wires -_- should have noticed that when reinstalling the new coil pack.
18 yrs old, senior in highschool, and work 45+hours a week at an autobody shop. but no ill buy a non running 7mgte swapped supra lol the heart ache was worth it. hopefully shes running saturday (when my coils come in the mail)
Old 11-05-2009, 05:07 AM   #10
You're more likely to destroy the igniter or ECU from shorts in that area then the coils.
Which wires were shorted? Post colors and pin numbers: http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=040
You really need to dig in and clean up that harness if you've got that many exposed wires... it's possible there's a lot more damage than just that unless you know that area's screwed up just from someone dicking with it in the past.
Measure the resistance across all of the coils and compare, that'll help you identify which ones really are suspect... if any. The process is covered in the link I gave you, did you bother to do it? http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=12
coil pack help dieseltech24179 MKIII Supra 1 11-30-2008 11:32 AM
coil pack grounds gomezmk MKIII Supra 1 01-01-2008 05:01 AM
Distrubtor Question kidsusukigsxr Non-Generation Specific Questions 5 02-09-2007 10:45 PM
