Old 11-01-2009, 05:00 PM   #1
Default errer codes
any help as to narrowing the problem down would be great!
  • Ignition switch circuit
  • Ignition switch
  • Main relay circuit
  • Main relay
    Ill replace all if i have to, but if any one has any past experience with these failing in there supra i would apreciate...
Old 11-01-2009, 05:21 PM   #2
Specifically what error code are you getting? (typing with acrylic nails is a BITCH)
Old 11-03-2009, 02:34 PM   #3
i only get error code 11 2 blinks 1 after the other,
already changed the ecu
anything... would be great
Old 11-04-2009, 01:16 AM   #4
Well, the first line of business would be testing for voltage drop across +B and +B1 at the ECU.
This is more than you need to look at, but it shows the ECU pinout:
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=30
Might also test to see what the drop is across the Batt line as well.
I suspect you're looking at either a bad EFI relay or some bad wiring.
Old 11-04-2009, 02:11 PM   #5
thanks ill replace those first!
Edit: Electrical / relay / fuses is not my show...
ill take as much info on it as i can thanks for the help!
Old 11-08-2009, 01:38 AM   #6
ok so i replaced:
all fuses
EFI main relay
Fusible link AM1 40A
Fusible link AM2 30A
(ECU a month ago)
it runs a lil better, but i cannot find the fusible link 2.0L and have yet to change the Fusible link ALT 100A(wich is burnt and ugly lookin, also looks like it melted a spot on
#2 Junction block lid
after that and some other cheking ill look and see if i get any error codes..
Old 11-08-2009, 07:04 PM   #7
You're on the right path. Hopefully it's not a spot of bad wiring... patching the engine harnesses on these cars sucks.
Checking codes.. dunewarz MKIII Supra 2 05-08-2009 03:44 AM
Codes 25,26,51! justin1642 MKIII Supra 11 08-30-2007 08:08 PM
codes 22 24 31 kidthunder650 MKIII Supra 16 04-12-2007 11:54 PM
Got Codes? h8z2luze MKIII Supra 14 08-29-2006 01:48 AM
fault codes on a newly re-headed supra lethalwithasupra Non-Generation Specific Questions 5 09-28-2005 08:22 AM
